Lifting questions
  • 31 Replies
  • 5907 Views
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: Lifting questions
« Reply #30 on: April 09, 2010, 04:27:08 PM »
"I got the 235's on the advice posted here and I'm glad I followed it.
My DD commute is over 60 miles round trip and has a lot of stop and go. No highway driving.
The acceleration is as poor as I can tolerate, if the tires were any bigger, I'd have to swap out the 5.12 gears."
Blue Meanie, I just noticed your comment on "having to swap out your 5.12 gears".  I'm thinking your 2 liter Tracker with the auto tranny came with 4.88 gear sets in it and unless you have already swapped out the stock gears for a set of higher 5.12 (Tracker/Gv) gears, you still have the option of jumping up to a set of readily available gears for your truck.  You would gain ALOT of gear generated torque running 235s without a huge reduction in MPG.   Just a thought.
« Last Edit: April 09, 2010, 04:29:33 PM by nprecon »
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #31 on: April 10, 2010, 05:45:35 AM »
I swapped out 205 60 16 for 235 75 15. I found this change to gain a slight improvement in milage and improved steering.
