Samurai stereo system problem
  • 2668 Views
« on: January 10, 2010, 09:54:40 PM »
I bought a CD player to throw in my samurai. there wasnt one there when i bought it, when i go to hook up the hot wire(red) memory wire (yellow) that where already there, along with the ground wire, there is no power? anybody else have this problem? should i just run my own wire to the battery? or maybe splice onto an ignition hot wire?
Re: Samurai stereo system problem
« Reply #1 on: January 11, 2010, 09:35:08 AM »
Check the radio fuse? I had to plug in the antenna wire to get my radio to work
after I replaced the little lights that burned out in it, I thought I ruined it at first
« Reply #2 on: January 11, 2010, 05:43:36 PM »
checked the fuse, tried the antenna thing...i think im gonna just run new wire to the battery and just have to manually shut it off and on every time i want to use it.
« Reply #3 on: January 11, 2010, 07:32:26 PM »
Sounds like the easy fix, or find a hot when ignition on wire to run it from,
and use the battery lead to power the memory
Offline maddoghd
  • 23
« Reply #4 on: January 15, 2010, 08:53:17 AM »
Use a test light to check the wires.  If you dont have it is a good investment for about $25.
« Reply #5 on: January 17, 2010, 12:17:11 PM »
I clipped onto the brake light wire connector as it is closer than going directly back to the battery.
Offline Wook660
« Reply #6 on: January 22, 2010, 03:38:20 PM »
Isn't the yellow wire usually 12v+ ignition and the red is the 12v+ memory/constant.  That's how all the car stereos I've installed have been.  Give that a try.
