Help with Intermittent engine power loss
  • 1541 Views
« on: January 06, 2010, 05:47:45 PM »
1990 Tracker with stock engine, free flowing intake and exhaust.  Occasionally will lose engine power.  On a typical hill that I drive 65mph, will only pull at 45mph.  Engine still runs smooth, just with less power.  The problem is unpredictable.  Timing is correct, new plugs, new fuel filter, gas purchased from same vendor for over a year, daily driver.  Noticed my gas mileage dropped from the usual 20mph to 15 mph on the last two tank fills. Any ideas would be greatly appreciated.
Offline jawman
  • 406
  • 1234
Re: Help with Intermittent engine power loss
« Reply #1 on: January 06, 2010, 08:30:17 PM »
if it did it all the time it is a head gasket, but if it is occasionally it is probably a sensor
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
« Reply #2 on: January 07, 2010, 08:59:17 AM »
Failing fuel pump? Tap into and watch a fuel pressure gauge and see if the
pressure drops when the power is down
« Reply #3 on: January 07, 2010, 02:47:05 PM »
15 mpg? Man I thought mine was a fuel sucker at 22mpg. What kind of lift and tires you got on that rig anyway?
Offline ranger88den
  • 279
« Reply #4 on: January 12, 2010, 09:40:42 AM »
Based on jawman's contention, have you done a compression test?
