yj leaf springs?
  • 2825 Views
Offline zukibalz
  • 16
yj leaf springs?
« on: January 05, 2010, 12:47:49 PM »
if i swap out my springs for yj stock bent leaf springs. how much lift will i get out of it or will it stay same height? iam new to this stuff so please bare with me and thanks in advance
Re: yj leaf springs?
« Reply #1 on: January 05, 2010, 07:10:14 PM »
Most people see about 2-3 inches of lift from the YJ spring conversion kits.  Combined with a SPOA kit that brings you to 7-8" above stock, plenty of room for 33-35" tires.
When you say bent leaf springs do you mean lifted ones?  If so you will need to combine the numbers.
Offline my996duc1
  • 222
« Reply #2 on: January 09, 2010, 04:22:26 AM »
I think you will have alot of factors to consider into the equation when figuring out how much lift you will get from a set of YJ springs..... weight of the vehicle to include heavy bumpers, winch, ect.... also how many miles are on the donor YJ springs.
I was running a set of 2" lifted Bonz-Eye Samurai springs and switched to YJ 5 pack springs on all four corners. I was actually about 1/4 - 1/2" less lift after swapping to YJ springs. I made a set of 6 pack YJ springs to lift me back up a bit and now I sit about 1" more than I was with the 2" lifted Samurai springs.
Right now I am sitting at 23 3/4" to the bottom of the rockers on 31" tires.
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
