Hi.
Kinda new to this site.
Owner -Resurrection Iron Works.
I recently started a Samurai build and have been contemplating the very thing we are now discussing.
After researching all of these swaps listed and a few more that were overlooked. I have decided to go with a Datsun L-18
With a Datsun dog leg 5 speed.
The L-18 produces 105 hp (stock) carbureted. This engine is known for its power, it's ability to spool , and it's reliability.
While the L-18s are becoming scarce the L-16 Datsun motor at 96hp (carburetor) is prevalent and cheap.
Dimensional they are very similar to the above mentioned 4 bangers but produce better power without the need of computers and expensive and troublesome EFI units.
I grew up racing Datsun 510s and Z cars . I may have a bit of a love affair with these engines.. But it is well deserved...
The engine pictured is a duel curbed SSS 1800 ( L-18T) 110hp on regular gas. 102 fb of torque. and will run at 8000 rpm all day.
Its mated to a drop pan Datsun 4 speed (Bullet proof tranny)
We installed it into a 1966 MGB With amazing results......
With an Iron block and an aluminum head it going to be slightly heavier than the 1.3 , but not enough to make a significant difference.
Once we get the new engine prepared for the install I will start a build thread on this site......Boxcar...
I gues I should mention...The engine for the Samurai will not be running duel carbs . It will be preped with a holly 2bbl.
on a Bob Sharp Manifold. L-20b stock cam - Mallorym electromic ignition......etc..
