Trans mount 87 samauri
  • 1201 Views
« on: December 22, 2009, 04:57:54 PM »
Should I worry about the front drive line contacting the trans mount I have about 6 inches of lift stock springs with spoa and shackle lift :)
Re: Trans mount 87 samauri
« Reply #1 on: December 23, 2009, 01:19:10 PM »
Do you mean the cross-bar?  You should be fine.  Some people have run into a rubbing issue when they install some 'bulletproof' t-case mounts made out of poly spacers as they are shorter then the stock length but just double stack the spacers underneath the t-case and you should be fine.
