Front Dif on tracker
  • 1201 Views
« on: December 19, 2009, 08:29:19 PM »
The short side axle keeps popping out if the dif housing,
Does any one know why or what has to be done to correct this issue,
I installed a Calamini 3" lift, on the orginal install the axle stayed in place
Re: Front Dif on tracker
« Reply #1 on: December 21, 2009, 07:48:35 PM »
The clip on the end of the shaft is what holds these in place, if it's
broken (gone) or just collapsed, it won't hold, on the flip side, if it's
too tight the axle is a #%$^#& to get out, I sheared one of those
little buggers in half removing an axle from a GV front end, beat the
crap out of the axle too, good thing I was making a flange side to
run the same half for both sides
