Vacuum lines
  • 1556 Views
Offline cstello
  • 33
Vacuum lines
« on: December 16, 2009, 10:20:24 AM »
Ok, I want to change my intake to a K&N and I have seen people remove a lot of stuff off a Samurai motor that is un necessary. My question is what vacuum lines can I cap off? BTW I have a 86 samurai 1.3 Carbureted
« Last Edit: December 16, 2009, 10:25:47 AM by cstello »
Re: Vacuum lines
« Reply #1 on: December 17, 2009, 11:18:26 AM »
The stock hitachi carb requires most of those vacuum lines, I wouldn't look at capping them off or removing them unless you switch to a Webber setup or a side-draft.
Offline jtigki
  • 43
Re: Vacuum lines
« Reply #2 on: December 18, 2009, 03:36:21 PM »
Hi! maybe someone could help me! i rebuilt my engine I cap off all the lines except the vacuum advance for the dist. my question is I got a weber with K & N its the PVC I'm problem I don't no where to connect the line to ? my valve cover I got a very smal filter on it!
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Vacuum lines
« Reply #3 on: December 18, 2009, 08:04:25 PM »
If you go to Acjk's FAQ and do a search for factory service manual or fsm, you will find a page containing the 1988 Samurai Factory Service Manual in three parts.
The second part of the FSM contains a drawing of the emission control system - Figure 5-1-1 on page 5-2.  It shows that the Positive Crankcase Ventilation (PCV) valve is connected through a tee to the valve cover and a port on the air filter.
I hope that this helps!
Ack
