Cheap intake for 8v
  • 2299 Views
Offline Lunchbox5k
  • 46
Cheap intake for 8v
« on: December 09, 2009, 03:46:48 PM »
I have been running this mod for a little over a year and have been meaning to share with the rest of you guys. Its a 2.5in to 3.5in adapter and a 3.5in cone filter. Parts ran less than $30 at checker/ shucks. Works very well, only had if fall off once and that was my fault i had just cleaned the filter and forgot to tighten it all the way.
91 Sidekick 8v
LSD in rear
Custom intake
Offline Lunchbox5k
  • 46
Re: Cheap intake for 8v
« Reply #1 on: December 09, 2009, 04:01:35 PM »
One more thing I forgot to mention, Im going to build a ram air duct into the hood using a third brake light housing out of a hyundai. Then we are going to construct an sheet metal air box around the cone and mount just below the intake. Those of you who have 8v should know just where Im talking about. In theory it should work, don't know till I try. Hopefully should have this done in the next two weeks, I'm waiting on the temp to go up, been in the single digits for almost a week.
91 Sidekick 8v
LSD in rear
Custom intake
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #2 on: December 10, 2009, 06:06:02 PM »
should put a tube exteding it out farther its only $15 more, your just sucking hot air.
« Reply #3 on: December 11, 2009, 01:28:28 PM »
Putting another heat shield underneath it should help keep the cold air coming in, especially if he installs an air ram.  Nice little adapter setup though.  Good find.  :)
Offline Lunchbox5k
  • 46
« Reply #4 on: December 12, 2009, 08:37:35 AM »
I have tried putting a tube off the end and running it over to the factory location, it just didn't have the same amount of power and throttle response.
91 Sidekick 8v
LSD in rear
Custom intake
Offline cwymer
  • 33
« Reply #5 on: December 12, 2009, 10:47:02 AM »
i have the exact same setup on my 8v.  mine dosn't look as fancy as your pic.  i have never had any problems with mine.  I am also considering a ram air setup with mine.    i cant wait to see your pix.
89 sidekick 2.5" body lift coil spacers up front running on 31X10.50's.  Custom push bar up front.
« Reply #6 on: December 14, 2009, 09:48:40 PM »
Since I removed the turbo, I have the same filter setup, mostly because the stock
air hose wont go from the filter to the engine because of the body lift
