budget upgrades for 1994 suzuki sidekick
  • 10 Replies
  • 5668 Views
Offline alexm
  • 17
« on: December 01, 2009, 08:31:47 AM »
i have a 1994 suzuki sidekick with its stock 1.6L 16-valve. i would love to know of any mild modifications that can be done on a limited budget.
wider the tire the narower the rim
Re: budget upgrades for 1994 suzuki sidekick
« Reply #1 on: December 01, 2009, 11:59:13 AM »
Quick and Easy is the spacer lift and throw some 30" tires underneath it.
What are you looking to do with the vehicle?
Offline alexm
  • 17
« Reply #2 on: December 02, 2009, 08:24:28 AM »
I all ready have the lift kits installed and a set of both agressive 29's and a set of mild 32's  just want to know what i can do to get more power from the engine.
Offline ToyYoda
  • 226
« Reply #3 on: December 02, 2009, 05:44:35 PM »
Several X90 club members which have 16v motors have tried different headers, ing. systems & air filters. We have come up with these mods. Doug Thorley "ceramic" headers, Nology wires (capasitor wires) & a K&N look-a-like air filter. Noticable power & better MPG. The system is very dependable as well.
« Last Edit: December 02, 2009, 05:50:15 PM by ToyYoda »
« Reply #4 on: December 03, 2009, 01:21:46 AM »
ToyYoda:
Do you see much of a boost from the Nology wires wires?
Offline ToyYoda
  • 226
« Reply #5 on: December 03, 2009, 08:48:52 AM »
Veh. starts faster & quicker throttle response. What I like best is the Suzuki's stock ign. is untouched. We ran a few different "high output" systems & had one fail miles from no where. After that it's been Nology. Yes over the years we had a Nology wire fail as well but it was hard to tell as it still works as a plug wire only. I know im not alone on the "if it's not broke don't fix it "! Depenability first. I know lots of people who have multi spark systems & high output ign. systems without trouble. I am not one of them. Rather run stock. Hope this info helps.
« Reply #6 on: December 05, 2009, 12:47:54 PM »
would a throttle body spacer work?
Offline alexm
  • 17
« Reply #7 on: December 09, 2009, 08:15:05 AM »
are there any throttle body spacers that are made for suzuki sidekicks
Offline AndrewK
  • 81
  • Of COURSE the ice is thick enough..
« Reply #8 on: December 09, 2009, 08:51:17 AM »
ToyYoda:
I see there your running a cone filter...I have a new cone that will fit...but thought everyone said to use the K&N higflow airbox filter instead??
« Last Edit: December 09, 2009, 01:57:03 PM by AndrewK »
97 Geo Tracker.  4x4.  5 Speed.  235/75/R15 ATR's, on Cragar 15x8's (a.k.a Jet Puffed).  Custom tubular safari rack. Custom light bar, 4x Baja spots.  Bedliner interior on its way..
Offline alexm
  • 17
« Reply #9 on: December 09, 2009, 11:59:21 AM »
no thats nott mine I still have the stock airbox
Offline ToyYoda
  • 226
« Reply #10 on: December 09, 2009, 08:22:54 PM »
I ran a cone type filter as it gives the motor a little boost & i had it at the time. Yes a K&N in the stock box works well & protects from dirt, mudd & under hood temp. Keep in mind the "stock box" is part of the air restriction. K&N helps. I now have a "modified" stock box with K&N.
