I run that 260 cam in my 88 sammy with a 1.3 ported the intake. head and got rid of all the emission stuff. weber on it. too and header. I am running 18 degrees on the timing. ngk plugs. thing runs out sweet pulls my 30 inch tires all day in 5th. makes a big differance. going to rocky road and get that adjustable cam gear from them to degree the cam. hear that makes a big diff too.
Well, pretty much the same mods here, but also K&N air, valves from 1.6 8v motor with 5 angle profile, high compression pistons and sport valve guides, MSD coil and wires + IW16 Iridium plugs with 1.2mm gap, and 17 degrees of timing.
So you're saying that 260 cam has made noticeable difference, what with low-end torque, say from 1.200 to 2.000 rpms and what happens above 6.000 rpms? Reason I ask is because the cam is only thing that I need in my engine to be done, CD ignition box is comming in a few weeks.
Does your mileage suffer after installing new cam?
