cam???
  • 18 Replies
  • 6360 Views
Offline Tracker-Kid
  • 50
cam???
« on: November 27, 2009, 11:21:30 PM »
ok so i just bought athe 260 cam from low range and i was just wondering if anyone has useds this and if its good or not and i would also like to know the lift and duration of the stock cam
thanks
IF ITS BROKEN.....  WELD IT!!
Offline S.Sidekick
  • 378
  • Suzi Suzuki
Re: cam???
« Reply #1 on: November 30, 2009, 07:44:39 AM »
dont know much about that stuff, but is it a 16 valve or 8 valve motor your putting it in? I want to do that mod but am a little sketchy on how hard it is to put in? can you keep me posted?
Offline obradleyo
  • 45
Re: cam???
« Reply #2 on: December 02, 2009, 06:43:53 PM »
I have the torquer cam from hawks.  I also have a cone air filter and a mangna flow muffler with 2" pipe all the way back. I got the magna flow after the cam . With just the cam I didn't notice much but with the cam and muffler I can now spin my 31" mt's. I can;t wait till I get my new header...hope that helps
1995 Kicker 5 speed, 4 dr, 4wd, Ac,Ps 16v 31" GT radial mudders,Calmini 3+3, torquer cam, magna flow with 2" tail pipe, calmini steering stablizer....... Sacramento,ca IMG]http://i388.photobucket.com/albums/oo327/obradleyo/rock.jpg[/IMG]
Offline Tracker-Kid
  • 50
Re: cam???
« Reply #3 on: December 02, 2009, 09:12:34 PM »
sweet thats great i already have an exhust cant wait to spin my 31s. il keep you guys posted
Offline S.Sidekick
  • 378
  • Suzi Suzuki
Re: cam???
« Reply #4 on: December 03, 2009, 03:30:40 PM »
ya i got a full 2" cold air intake, long tube header, high flow cat, spin tech exhaust and 2 1/2 pipeing so i think thats the rout ill take, what was need to be taken off to install the cam??
Offline Tracker-Kid
  • 50
Re: cam???
« Reply #5 on: December 05, 2009, 05:13:32 PM »
i had to pull the head off seeing as the cam slides out the back. but for how much it costs and how much work it was to get in i didnt see very much power increase. im gonna try messin with the timing and some things if anyone has any ideas to get some more hp out of it i would appreciate it thanks
Offline S.Sidekick
  • 378
  • Suzi Suzuki
Re: cam???
« Reply #6 on: December 06, 2009, 09:34:36 AM »
dang thats what i thought would needed to be done, but is your motor 8v or 16v, are they the same for as how to get the cam out, i was thinking the 16v was a over head, and would just need valve cover removal, and stuff like that?
Offline Dimitros
  • 75
Re: cam???
« Reply #7 on: December 06, 2009, 10:33:15 PM »
For getting more noticeable power gains from 260 cam one should have at least better than stock flowing intake + properly tuned carb and good exhaust with header, next would be ignition&timing.
While the head off the engine porting is also very good idea.
95 Samurai, 1.3, high comp.pistons, ported/grinded head, 1.6 valves, bored intake, Solex carb, K&N air, MSD Coil-Blaster+MSD 8.5 wires+Denso Iridium IW16 plugs, Calmini Tri-Y heder, Cherry-Bomb+Bosal custom exhaust, GRS II 4.89 T-case, 3.92:1 R&Ps, Calmini 3.5" susp., 30" BFG ATs, AVM 538 hubs...
Offline RNAHAKU
Re: cam???
« Reply #8 on: December 07, 2009, 06:24:51 AM »
i am running a hawk 260 with doug thorlley header  2 inch exhaust flowmaster(series 40) no cat and cold air intake i have a noticeable increase in torque not a bunch a horse power in am running a newly rebuilt 8v  with about 600 miles on it right now  still tryin to get the timing right i have a high cold start idle of about 2600rpm  and once the thermostat opens i get about a 600 rpm surge for a couple minutes i am currently running timing at about 9.5 deg.  need to get the cold start down and figure out the surge
89 track
thorley header 2inch flowmaster series 40
calmini hi flow intake
arb front and rear
4.5 rro lift
31x9.5  tsl radial  rock crawler 15x7 2.5 offset
petro cage
Offline Snorkeld_Zuk
  • 94
  • HAMMER DOWN!
Re: cam???
« Reply #9 on: December 07, 2009, 08:33:44 PM »
The 16v the cam comes out the top, with the 1.3/1.6 8v it slides out the back. I prefer to pull the whole engine rather than just the head, then I don't have to buy a head gasket. I'm not familiar with any cams available for the 1.6.
88 Samurai: (White Zuk) Lifted, locked, geared, caged, etc
88.5 Samurai: (Red Zuk) Project pile
Offline sammypro.com
  • 153
Re: cam???
« Reply #10 on: December 08, 2009, 12:15:09 PM »
X2  ON PULLING THE MOTOR!!!! It may seem more intimidating, but well worth the hassle,,,good time to do rear main seal too!!
Offline Tracker-Kid
  • 50
Re: cam???
« Reply #11 on: December 08, 2009, 06:15:24 PM »
im runnin the 8v and i have a cold air intake and a free flowing exhust from the cat back im ordering the header this week. im also running 10 degrees of timing but im in reno so i think the elavation is like 4400 or so dont know if this helps figur my problem out but thanks for the input any more ia appreciated thanks
« Last Edit: December 08, 2009, 06:28:06 PM by Tracker-Kid »
Offline yzf438
  • 94
Re: cam???
« Reply #12 on: January 21, 2010, 06:01:36 PM »
I run that 260 cam in my 88 sammy with a 1.3 ported the intake. head and got rid of all the emission stuff.  weber on it. too and header.  I am running 18 degrees on the timing.  ngk plugs.  thing runs out sweet pulls my 30 inch tires all day in 5th. makes a big differance.  going to rocky road and get that adjustable cam gear from them to degree the cam.  hear that makes a big diff too.
Offline zukimoo
  • 330
Re: cam???
« Reply #13 on: January 26, 2010, 07:47:09 PM »
pull the motor and if you're not sure to be able to do it then pay someone.....at the same time check all the seals....do not pull the head.....big can of worms
06 Baja Buggy
Offline Dimitros
  • 75
Re: cam???
« Reply #14 on: January 30, 2010, 06:35:38 AM »
Well, pretty much the same mods here, but also K&N air, valves from 1.6 8v motor with 5 angle profile, high compression pistons and sport valve guides, MSD coil and wires + IW16 Iridium plugs with 1.2mm gap, and 17 degrees of timing.
So you're saying that 260 cam has made noticeable difference, what with low-end torque, say from 1.200 to 2.000 rpms and what happens above 6.000 rpms? Reason I ask is because the cam is only thing that I need in my engine to be done, CD ignition box is comming in a few weeks.
Does your mileage suffer after installing new cam?
