Lockers
  • 2399 Views
Offline AndrewK
  • 81
  • Of COURSE the ice is thick enough..
Lockers
« on: November 27, 2009, 12:34:00 PM »
Hey Everyone.
After seeing three different spots around winnipeg,  i've settled in on my tracker build.  None of the places really require much lift, and the bigger tires help with that anyway.   My next step is to install lockers.
Could someone explain what the trackers have/ need in terms of lockers?   i thought the rear already was locked when in 4x4...
Thanks Guys.
97 Geo Tracker.  4x4.  5 Speed.  235/75/R15 ATR's, on Cragar 15x8's (a.k.a Jet Puffed).  Custom tubular safari rack. Custom light bar, 4x Baja spots.  Bedliner interior on its way..
Offline hot-wheels
  • 41
Re: Lockers
« Reply #1 on: November 27, 2009, 02:09:11 PM »
original track/kick do not have any locker but if you want cheap you weld the rear diff or put a spool and the front can use a lockright type locker.
better is the ARB air locker but much more expensive.
two most important things for me :first wheeling as much possible and the second  fly fishing ho! live is goood.
Offline fuzzy1
  • 350
Non Illegitimi Conterat
Re: Lockers
« Reply #3 on: November 27, 2009, 05:32:18 PM »
Don't weld the rear diff if you live where it snows, this can make driving
very dangerous causing you to slid off the road
Lockers are not to much, about $250 in the US, check the advertising directory
Offline AndrewK
  • 81
Re: Lockers
« Reply #4 on: November 27, 2009, 09:51:48 PM »
Sweet Wild, i'll look into it.    and that is the main thing,  here in winnipeg, we are most of the time stuck in ice and deep snow at -50 weather.    So, sliding around it not a priority.  But being able to get unstuck IS.  Deep snow is going to be the tracker's biggest enemy (seeing as its my winter car)   I'll look into a good rear locker.
thanks again,  knew you'd have something helpful on this.
Re: Lockers
« Reply #5 on: November 28, 2009, 02:00:35 PM »
with power on a locker will slide you also, get the feel for it before you
push your limits on ice and snow
Re: Lockers
« Reply #6 on: November 29, 2009, 07:57:03 AM »
Keep an eye on craigsllist and ZW classifieds where there just was an ARB for the rear for $500 (which I would have bought, if I wasn't sleeping).  Lockers set up right are OK for the rear, but an ARB up front is just totally awesome, and they work better than stock even unlocked.
Unless you know what you are doing, at least take the differential to a shop, and have them set it up for you.  If not set up right, they do not work right, you won't be happy, they wear the gears wrong, it starts to whine, you won't be happy, and they do not work right.  Or, you could be lucky (or talented).
Offline Snorkeld_Zuk
  • 94
  • HAMMER DOWN!
Re: Lockers
« Reply #7 on: December 07, 2009, 08:53:14 PM »
a lockrite literally just slips right in, ANYONE can install it. In 2wd it will be sideways in the ice, ever watch Drifting? But in 4wd it will be impressive. Bang for the buck you cant beat the lockrite/aussie/detroit ez
88 Samurai: (White Zuk) Lifted, locked, geared, caged, etc
88.5 Samurai: (Red Zuk) Project pile
