Technical Discussion - Performance / Modify
T-Case Crossmember
T-Case Crossmember
Minmatar
262
That lake is just too clean....right zuki? >=)
T-Case Crossmember
November 24, 2009, 10:50:13 AM »
So i have a 1993 4 door Suzuki.
I bought a 1994 4d cross member thinking it would be the same........wrong. The 93 had this open C frame design and thick medal compared to the 94's thin flat 3/16" bubble stamped cross member. Anyone know if it will still measure up?
<)O.o(> NO!!!!! *as the sidekick rolls* My beer =(
wildgoody
8134
67
Re: T-Case Crossmember
November 29, 2009, 10:52:04 AM »
Should fit, the frame and transfer/tranny assembly didn't change any,
are you sure it's not a part from a Sport instead? those could be different
ncspack7civic
108
November 29, 2009, 12:36:34 PM »
Yea i just had to swap my transfer case crossmember since it was bent real bad. I had the same concern since i had the stamped C shape and the one that was sent to me was the flat bubble one. They swap with no problems. I think im going to like the bubble crossmember it seems to hug the underside alittle bit tighter. I kept getting the stamped C crossmember hung up on thing and thats what did it in.
Skyhiranger
3734
122
I don't buy, what I can build
Reply #3 on:
December 01, 2009, 02:11:04 PM »
All 4wd crossmembers are interchangable....both 2 and 4 door, from 89 to at least 98.
Well, except for probably the 96-98 sidekick sports.....I think the frames are wider, so therefore they won't interchange, obviously.
