T-case Problems
  • 1700 Views
Offline zuki87jx
  • 31
T-case Problems
« on: November 23, 2009, 03:25:47 PM »
When i bought my samurai I was testing the 4 wheel drive and i got it to go into 4 hi, neutral and 4 lo but it doesn't seem to want to scoot over to go up into to 2 hi. I put a new shift sheet and it still didn't fix the problem I am a little stumped. anyone got an Idea?
Re: T-case Problems
« Reply #1 on: November 23, 2009, 10:31:46 PM »
pull the shifter out and take a big screw driver and try to line up the two shafts so the shifter will move side to side.
Offline zukimoo
  • 330
Re: T-case Problems
« Reply #2 on: November 24, 2009, 05:23:33 PM »
you just need to re-align the shift forks. For some reason I've got  the same problem. Mine sticks in neutral. I changed the sheet, shifter and it still does it. I just don't clip the shifter back in and let it loose.
06 Baja Buggy
Offline zuki87jx
  • 31
Re: T-case Problems
« Reply #3 on: November 24, 2009, 07:17:51 PM »
Thanks alot guys hopefully tomorrow ill get off at a decent time so i can fix that. another question ive been riding with it in 4hi for a couple of weeks now mostly just back and forth to work ( 40 miles round trip) is that going to hurt any thing?
Re: T-case Problems
« Reply #4 on: November 25, 2009, 12:22:35 PM »
I would unlock your front hubs just to be on the safe side but you should be fine.
Re: T-case Problems
« Reply #5 on: November 25, 2009, 07:31:54 PM »
DOUBLE CLICK ON THE EVIL TWIN BANNER AND ADD TWIN STICK TO YOUR RIDE! YOU WILL NEVER HAVE THAT PROBLEM AGAIN!
