do the equators have the same front diff as a frontier?
  • 2900 Views
Offline mersingt
« on: November 22, 2009, 06:50:03 AM »
if so its weak and watch out.....
96 geo tracker 2 door
31" tsl radials
3 inch calmini
4 door springs
  • 6554
  • 64
Re: do the equators have the same front diff as a frontier?
« Reply #1 on: November 23, 2009, 08:15:54 AM »
How do you know? This sound like some very important information...
Offline mersingt
« Reply #2 on: December 03, 2009, 07:23:41 PM »
well the equator is made by nissan right? well the frontier and xterra have crappy front diffs check out www.thenewx.com
31" tsl radials
3 inch calmini
4 door springs
  • 4314
  • 167
« Reply #3 on: February 25, 2010, 06:10:44 AM »
I fail to see the logic there - and the link to the newx website didn't make it any clearer.
That's like saying all Suzukis have weak front diffs because the GV has a weak front diff - when in reality some GVs (those with aluminum front diffs) have weak diffs, whilst others don't (some have steel diffs) and there are very few complaints about the Samurai & SJs.
As far as I can tell - in reality even the so called weak GV diffs are upto the task that Suzuki required of them - they don't start to break until folks start to abuse them, larger tires, lower gears, rock crawling, etc., etc., etc., - in my neck of the woods, it's mud & sand, and I've never heard of anyone here breaking one.
Where's your evidence ??
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
Offline Oscello
« Reply #4 on: March 23, 2010, 07:54:46 AM »
There is a sticky on the new x concerning diff failure.
http://www.thenewx.org/forum/showthread.php?t=5479
Do a search on "titan swap" alot of the frontier/xterra guys will swap basically the whole front suspension because they break the front diffs. Also the titan swap allows for more front end travel
http://ruggedrocksoffroad.com/blog/2009/01/06/lockn-it-up-update-on-2nd-gen-nissan-lockers/
http://www.clubxterra.org/forums/showthread.php?p=100179
http://www.nissanoffroad.net/messageboard/index.php?topic=5471.msg63118
This guy ended up doing a solid axle swap because he went through 2 diffs.
http://www.nissanoffroad.net/messageboard/index.php?topic=7587.0
« Last Edit: March 23, 2010, 08:03:54 AM by Oscello »
