Caster/camber issues after lift install?
  • 9 Replies
  • 5197 Views
« on: November 16, 2009, 06:31:14 PM »
I just got Jeff's 2 inch coil spacer lift put on my 03 tracker (2 door 4cyl) along with new rear shocks.  It looks awesome, and the parts seemed to be high quality.  My buddy (mechanic) noticed that the caster/camber is off now with the lft.  The front tires "tow" is off, as the front tires appear to be slightly angled out now.  I've heard that I should expect some settling to occur with the lift before considering alignment.  Has anybody noticed this on a fresh lift?  Should I expect this to resolve after a couple weeks?
-Thanks
2003 chevy tracker (2.0L-auto-2 door-soft top)
MODS SO FAR....
-235/75/15 w/cragar soft 8's
-painted grill/graphics removed
-bull bar + off road lights
-Jeff's 2" spacer lift w/new rear shocks
-flowtech muffler
-Pacer Fender Flares
Offline Armour
  • 360
Re: Caster/camber issues after lift install?
« Reply #1 on: November 16, 2009, 07:41:42 PM »
You shouldn't get any settling with spring spacers. Only if you have replaced the springs also. I would go ahead and get it aligned before it starts to wear your tires.
Offline sir lance
  • 342
  • I love my XL-7
« Reply #2 on: November 16, 2009, 10:00:56 PM »
with any lift an alignment is necessary
post pics :)
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #3 on: November 17, 2009, 05:37:48 AM »
x2 on lance's comment.
The alignment place may balk at fixing the camber saying that it is "not adjustable".
There are camber adjuster bolts available for the Tracker/Sidekick.
http://www.acksfaq.com/camberbolts.htm
(found by doing a search for camber at Ack's FAQ - see link in signature.)
Show that information to them. maybe they will do the alignment.  Then again, they may balk at the possibile liability risk.  If so,  you'll have to do it yourself.  The above search also contains a link to an installation video provided by the part manufacturer - Specialty Products.
I hope that this helps!
Ack
« Reply #4 on: November 17, 2009, 06:21:16 AM »
Thanks for the help guys.  As always, the answers to any tracker problem can be found on this forum.  I thought I had thoroughly researched this lift before I did it, but I was not aware that my camber could/would be affected.  I'll contact my local shop to see what they can do, and if that doesn't work, I'll go for the bolts.
-Dan
MODS SO FAR....
-flowtech muffler
Offline bzzr2
  • 1011
« Reply #5 on: November 17, 2009, 06:40:28 AM »
a little bit of slotting in the strut holes goes a long way for zero dollars.  just find a shop that understands and they will do it for you.
09 taco reg cab short box 4x4
« Reply #6 on: November 17, 2009, 06:48:16 AM »
Good idea.  I would prefer to have this done as cheaply as possible.  I'll see is "slotting the strut holes" is an option.
-Dan
MODS SO FAR....
-flowtech muffler
Offline sir lance
  • 342
  • I love my XL-7
« Reply #7 on: November 17, 2009, 11:35:17 AM »
i have also used 1 size smaller diameter bolts in the upper holes, this is also cheap and gives room for adjustment
-Lance
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #8 on: November 18, 2009, 02:24:18 PM »
Agreed.  Get your truck aligned.  Then have them check it again after a couple weeks of driving.  I have the 1.5 inch coil spacers on the front of mine as well.  Either they didn't seat the coils well or the springs moved and settled, but the end result is I did experience significant wear on the inside of my tires after driving about 5K on them before I noticed the wear and had it realigned.  I'm running those on the rear of my truck trying to even out the wear on them now.
Slotting the top strut holes is a cheap, safe, easy and reliable way to get your alignment back into spec and virtually any alignment shop should be able to accomplish the minor enlarging of the holes.  The Camber bolts are salty to buy and are not as thick as the stock bolts (because of the camber).  The stock bolts won't fail you when properly snugged up.
« Reply #9 on: November 19, 2009, 06:47:21 AM »
Unfortunately, I have not been able to find a shop willing to just "slot out the holes" for cheap around here.  Most of them seem absolutely clueless on how to handle the tracker.  I found a shop some distance away that specializes in doing allignments on lifted vehicles.  They sound like they will be able to slap some camber adjustment bolts in and take care of business.  Its painful in the wallet area, but I'd rather have it done right.  Thanks for all the help and advice on here.
MODS SO FAR....
-flowtech muffler
