YJ spring measurement
  • 1585 Views
Offline my996duc1
  • 222
« on: November 14, 2009, 02:53:52 AM »
Looking for measurement of a stock set of YJ springs....
I have a set that look pretty worn.
Can someone flip a set and measure from the surface/ground/workbench to the top of the center of the spring pack for me ?
Mine are at about 7.25" but wondering if I should try to use these or find another set before I do the swap.
Would like to get about 2" - 2.5" of lift out of the YJ swap.
Thanks !!
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Offline MetalZuki
  • 21
  • 1.3 litters of fury!!
    • My Myspace
Re: YJ spring measurement
« Reply #1 on: November 23, 2009, 08:15:26 AM »
i have a set that is pretty worn to but I will take a measurment this afternoon and let you know what I find
87 Zuki Samurai
Full propane system running forklift carb.
 SOA RUF and cj7 springs in back with m/l shackles
4 to 1 in T case
31-11.50-15 LTB's front and rear Lockrights All work done by me and my dad way to much body damage (only by me lol)
Offline my996duc1
  • 222
« Reply #2 on: November 26, 2009, 06:36:59 PM »
I have two sets of YJ springs here now. They are both measured at 7.25", so I am guessing they are good.
I have the rear installed and been running them for a few days. I will start to swap out the fronts on Sunday.
I might be about 1/2" more lift than I had with the BonZ-Eye 2" lift springs. The YJ 5 pack springs I am putting on have about 100,000 miles on them (what I was told), so hopefully they are all broke in and will ride nice.
Thanks for offering to help out.
« Reply #3 on: November 27, 2009, 10:03:15 AM »
If your going to go wheeling with the YJ springs I recommend installing a traction bar.  It doesn't take a whole lot to twist those softer springs up.
