Samurai Rock Assault Front 4340 Chromoly Axles
  • 0 Replies
  • 2180 Views
Offline Low Range
  • 192
    • Low Range Off-Road
« on: November 13, 2009, 01:58:09 PM »
At Low Range there are two things that we know all about, breaking parts and providing HD parts that can't be broken. That is why we carry the Rock Assault Front Axle Kit out of nothing less then 4340 chromoly. Started with a forged 4340 chromoly steel housing, cage, and race then used  grade 20 precision ball bearings.  We also redesigned the whole birfield with an extended and contoured cage, and relieved the bell so that it  allows for increased travel and angularity. High strength rolled splines (not cut, which is the weak point in most shafts). The shaft is a larger diameter than stock, and upgraded from 22 to 26 spline.
These also come with a One Time One Year, No Questions Asked Warranty. Just send in the broken axle and get a new one back. How can you beat that?
Please note, to install these front axle shafts into your Samurai, you will need to run 26 spline side gears in your front differential. This can be done by installing OEM rear side gears, purchasing new ones bellow or by purchasing a locker that already includes 26 spline side gears. Mini Spools do the same as well.
Kit includes:
Both Outer Birfields
Both Inner Axle Shafts
C-clips
Price: $235.00
