Technical Discussion - Beginner / Repair
transfer case pops out of 4wheel high....anyone know why?
riverman
6
November 12, 2009, 08:17:09 PM »
my 87 sammy always pops out of 4wheel drive high,,,does anyone know the reason why,,,it works fine in low lock,,,and i can hold it in high,but pops out randomly,,,thanks
captchee
224
Re: transfer case pops out of 4wheel high....anyone know why?
November 13, 2009, 04:25:21 PM »
well im guessing here but normaly a transfer poping out of gear id do to a bent shifting fork
zukimoo
330
2
November 13, 2009, 07:20:21 PM »
has the case been opened before? there are some shifter balls and if someone took one out then it wouldn't hold as good as stock.
06 Baja Buggy
dupont#24
48
2
Deer hunter
Reply #3 on:
November 14, 2009, 09:18:34 PM »
take the boot off and see if the shifter is hitting I ran into the same problem I took a sawssaw and cut it where it wouldn't hit any more boot covered it and never pop out again
zukimoo
330
2
Reply #4 on:
November 15, 2009, 11:51:03 AM »
did something get bent? are the t-case mounts broken to make the case twist? There is a reason for the contact. You can run a zuke for a long time with one broken mount but as soon as you break the second then you're screwed.
06 Baja Buggy
Cuthulu
384
I'd kill for a Nobel Peace Prize.
Reply #5 on:
November 15, 2009, 08:16:54 PM »
You might check the mounts too. I picked up a Ford cheep because it would not stay in 5th. I lent it to a buddy of mine and when I watched him back it up I could see the whole motor move underneath. Turned out it was a busted motor mount. Replaced it and sold it for a tidy profit.
ecoast
509
8
You tube my space, and I'll google your yahoo
Reply #6 on:
November 18, 2009, 04:34:49 AM »
It's prob. the shifter sheet.
Mine did this...and the next time out wheeling- stuck in neutral.
Pull knob, boot, 4 bolts, shifter. You'll most likely find a mess of black goo that used to be the bushing...
