samurai steering stabilizer recommendation
  • 3079 Views
« on: November 12, 2009, 06:43:20 PM »
I have an 88 samurai with 2" body lift and 30" tires  in the last few weeks I am getting some wheel wobble and I am thinking it is the stock stabilizer,any    recommendation on what stabilizer I should go with? Thanks Mike
« Last Edit: November 12, 2009, 06:47:17 PM by zuktinter »
Offline CspgsZuk
  • 10
  • Offroad since '71, Zuks since '88
Re: samurai steering stabilizer recommendation
« Reply #1 on: November 12, 2009, 08:45:27 PM »
I used an OME stabilizer for a few years until I went to power steering. I still have it. If you're interested PM me.
It is quite abit larger than stock and mounts like stock instead of a bracket on the pitman arm.
« Reply #2 on: November 19, 2009, 07:38:36 AM »
Does anyone know of one that its beefier than stock but bolts up as to the stock mounts?
« Reply #3 on: November 19, 2009, 12:04:49 PM »
The Stabalizer might help hide the wobble but you will just be hiding the rear problem.  I would look at your tie rod first, see if your joints are worn.  You might also want to have the balance on your tires checked.
« Reply #4 on: November 20, 2009, 06:47:11 PM »
the front end is tight the samurai only has 36K original miles on it,the over sized tires only have 1k on them but will definitely check the balancing on them.
« Reply #5 on: November 21, 2009, 12:16:16 PM »
Well I went and had my tires balances today and it turnes out my tires are out of round they are 15" 30  X 9.50 General grabber A/T tires with only about 1k miles on them  :-[
« Reply #6 on: November 21, 2009, 12:31:49 PM »
Can they true them up?
« Reply #7 on: November 22, 2009, 10:17:45 AM »
Check this out, found a"Gabriel Steering stabilzer Part # 14040" at Auto Zone. for 1987 Samurai.
