Transfer Case Vibrating/Shaking
  • 1571 Views
« on: November 02, 2009, 04:24:58 PM »
 I bought a Sammy that has a vibration in the transfer case up to 25 mph.  Do the transfer case arms come in one size fits all?  What brackets/arms/mounts would you recommend and why?
« Last Edit: November 02, 2009, 04:28:20 PM by elprincipal »
Re: Transfer Case Vibrating/Shaking
« Reply #1 on: November 03, 2009, 10:52:53 AM »
All the Sammy's have the same t-case mounts.  You may want to pull your t-case off and see if the long mount has been twisted up.
As for after-market kids I am a fan of the Snatch from ZOR.  One of the guys in the club just picked on up and it is one of the few that make removing the t-case easier then stock due to it's design.  But you really can't go wrong with any of the products out there.
You might also want to check your u-joints and bolts on the jack-shaft between your t-case and the transmission.
Offline zukimoo
  • 330
« Reply #2 on: November 03, 2009, 04:52:58 PM »
check the drive shaft bolts, u-joints and the get under the vehicle and push up on the t-case. the mounts break all the time. Look at the rear tranny mounts...it's very weak too and can cause some vibs.
06 Baja Buggy
