Bought The Trail Tough YJ Kit.... Have a few ?s
  • 20 Replies
  • 6683 Views
Offline Asbury030
  • 85
« on: October 30, 2009, 06:02:04 AM »
Hey guys well first off I bought the Trail Tough kit looks sweet once I get it all done but my concern is I am doing a complete off the frame resto so I see it uses some of the stock stuff like the u bolts but I could not get them off the were so rusted so I cut them is there any other stock parts I need to save for this lift and also can I just go to my local hardware store and buy the u bolts and if so what size would they need to be?
Online ebewley
  • 6551
  • 64
Re: Bought The Trail Tough YJ Kit.... Have a few ?s
« Reply #1 on: October 30, 2009, 08:18:18 AM »
Give Trail Tough a call and buy u-bolts from them or Sky at SORD. I just got a set from Sky and he has really nice quality u-bolts. The stuff you get at the hardware store are usually crappy. "Quality" u-bolts have a really thick flat washer and a deeper / taller nut that works better.
Good luck, Eric
phloop
« Reply #2 on: October 30, 2009, 08:14:18 PM »
Gotta give Sean a little love here, check out http://www.lowrangeoffroad.com/samsuspparts.htm a little over half way down, both stock and 2" extended U-bolts.
Offline zukimoo
  • 330
« Reply #3 on: November 01, 2009, 04:21:15 PM »
you local spring shop can get you some good u-bolts too....call them and they'll tell you how to measure. I've gotten a few sets made and they always work great...and they'll come with the good washers and double high nuts.
don't buy the hardware store junk....they are meant to hold something on a flag pole.
06 Baja Buggy
Offline Asbury030
  • 85
« Reply #4 on: November 03, 2009, 06:06:31 PM »
Hey does all this look right to you guys?
Offline RHodge
  • 523
« Reply #5 on: November 03, 2009, 08:57:15 PM »
Yep
Offline Asbury030
  • 85
« Reply #6 on: November 04, 2009, 04:20:30 AM »
K sweet thanks guys I appreciate all the help.
Online ebewley
  • 6551
  • 64
« Reply #7 on: November 04, 2009, 11:07:42 AM »
This lift is well documented here on our site. From the Gear Guide section there are two articles that will help.
http://www.zukiworld.com/month_050104/feature_trailtough_yjlift_install.htm
and
http://www.zukiworld.com/month_050104/feature_trailtough_questreview.htm
Good luck, Eric
Offline Asbury030
  • 85
« Reply #8 on: November 04, 2009, 03:02:02 PM »
When I take the old shock tower off I take the whole bump stop part off also?
« Last Edit: November 04, 2009, 03:06:15 PM by Asbury030 »
Offline locjaw
  • 2045
  • 22
« Reply #9 on: November 04, 2009, 08:01:18 PM »
trail toughs yj kit..........
Offline Asbury030
  • 85
« Reply #10 on: November 05, 2009, 07:06:27 AM »
Thats awesome!
Online ebewley
  • 6551
  • 64
« Reply #11 on: November 05, 2009, 07:32:04 AM »
I wouldn't... Where are you going to put a bumpstop? But seriously, if you look at the build article there are really detailed photos...
Offline Asbury030
  • 85
« Reply #12 on: November 05, 2009, 08:25:01 AM »
Yeah but on the pictures it looks like they took them off?
Offline my996duc1
  • 222
« Reply #13 on: November 05, 2009, 10:40:55 AM »
I am at the same point.... I want to set up the YJ swap correctly AND keep my bumpstops but the acticle shows to remove them.....
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Online ebewley
  • 6551
  • 64
« Reply #14 on: November 05, 2009, 12:35:53 PM »
Hmm, good point... It has been so long since I had that Samurai I had forgotten that the original bump stop perches were removed during installation. The Samurai in the article did not have traditional bump stops on it but used the rubber stop on the Deutsch tech shocks as a bump.
