10 inch rim
  • 2008 Views
Offline philc72
  • 65
10 inch rim
« on: October 29, 2009, 04:53:13 PM »
wondering if there would be any issues with 10" wide rim on a 2002 4 door with 235 tires found a set or cheap thaqnks
Re: 10 inch rim
« Reply #1 on: October 29, 2009, 05:05:19 PM »
235s are a little skinny on 10" rims, did they come off a low rider?
check the bolt pattern, 5.5 on 5 or is it 5 on 5.5? lol I don't remember
Offline philc72
  • 65
Re: 10 inch rim
« Reply #2 on: October 29, 2009, 07:27:37 PM »
The rims have no tires I have 235's I wondered if they might be too skinny as well lol Need rims cheap lol
Offline yellow2000S/R
  • 152
Re: 10 inch rim
« Reply #3 on: October 29, 2009, 10:06:06 PM »
Cragar Soft 8 and V-5 aren't cheap enough at 38-40 each? If you want to add some "bling" at a later time Cragar makes polished SS rings for the lips that you press on.
« Last Edit: October 29, 2009, 10:10:40 PM by yellow2000S/R »
Offline philc72
  • 65
Re: 10 inch rim
« Reply #4 on: October 30, 2009, 07:51:22 PM »
thanks I will check them out
Offline zukimoo
  • 330
Re: 10 inch rim
« Reply #5 on: October 31, 2009, 03:18:22 PM »
most places won't mount that size tire on the 10" rim and if they do they are taking a liability chance.
You'd be better off with a 7 or 8" rim. I run 30's on a 8" rim with a little offset and it works great. If you did manage to get them on then you'd have alot of exposed rim. I ran 10" wide on 10" rims and the rims were very beat up. To use the 10's you'd need a 12" wide tire.
06 Baja Buggy
Re: 10 inch rim
« Reply #6 on: November 01, 2009, 06:19:22 PM »
I run the Swamper 33-13.5-15 LTBs on an 8" rim
My spare is a 33-12.5-15 on a 7" rim
