Cooling system on a 93 4D Sidekick
  • 1849 Views
Offline Minmatar
  • 262
  • That lake is just too clean....right zuki? >=)
« on: October 22, 2009, 01:47:30 PM »
So i've been wondering why my motor is eating coolant. So yesterday when i got home i decided to test it out run all the air out on a new refill.
Now here's the noobish part.
I  opened her up and topped her off at the new radiator cap, tried to work as much air out through the hose, cranked her over and let her run for all of 4 sec before i started watching my own blow hole under the hood. (im used to running my motors with cap off to get air out. I know the thermostat is kinda finicky but the motor stays |removethispart|@ 1/4 - 1/2  on the temp gauge. Another thing, after topping it off last time i started plooming water vapor out my tailpipe until the motor was fully warmed up. No noticable power loss.
no sputtering of any sort. weird. whats your insight? Some say a thermostat thats almost closed causing back pressure but i dunno.
<)O.o(> NO!!!!! *as the sidekick rolls* My beer =(
jxben16
Re: Cooling system on a 93 4D Sidekick
« Reply #1 on: October 23, 2009, 08:12:26 AM »
i hate to say it, head gasket?
Offline Minmatar
  • 262
« Reply #2 on: October 23, 2009, 10:45:01 AM »
Im pretty sure the head gaskets going just gonna wait till i get a head rebuild. But trying to get one is ridiculous here in the PNW
« Reply #3 on: October 23, 2009, 06:03:27 PM »
You might give Liberty Overland a shout as they are just a bit to your south.  Eric could probably hook you up.  You have the 16v in that right?
Offline Minmatar
  • 262
« Reply #4 on: October 24, 2009, 01:49:38 AM »
yeah. I know the seals are do as welll as a good valve grind. I know i want to try the torquer cam as well. Just wondering if getting the block blueprinted is worth it. Or try rebuilding the bottom end on my own......
