help
  • 17 Replies
  • 3324 Views
Offline E_man
Re: help
« Reply #15 on: October 26, 2009, 10:47:51 PM »
no i put it on with the hole lined up
Re: help
« Reply #16 on: October 27, 2009, 12:29:33 AM »
OK, did you use plastigauge to see what the clearance was?
If you had oil pressure, it must be a tight tollerance bearing, or the wrong bearing in the package,
this would starve and roast the bearing
Offline captchee
  • 224
Re: help
« Reply #17 on: October 27, 2009, 04:11:30 PM »
 yep if all was done correctly then  its out of tolerances , eather the bearing , the journal  or the  conecting arm . cap itself
