Is it a big deal to use 80-90w gear oil in transmission of 96 manual tracker?
  • 3162 Views
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
Just curious if I shouldn't use 80-90 gear oil and should keep trying to find 75-90 oil?
Looking for opinions.
Thanks all.
Bash
Mean Green Wheeling Machine
Sup Bash, it's been a while.  :)  I use the 80-90 weight in mine without any issues.
Offline mike5721947
  • 545
i was told to run 80-90 by both a suzuki dealer and a specialty suzuki only shop.
i had it in my tranny and transfer case for 2 days. it was so bad i couldnt let my clutch out or it would stall in cold weather (the fluid was that thick)
granted thats in -40 degree weather. i run 75-85 synthetic in it since then and never had a problem with cold starting or running at all.
so for normal weather 80-90 is fine but if you get freakin cold in the winters its better to go with the 75-85 synthetic.
31" kumhos 3inchs of lift.
Out of curiosity, what weight motor oil do you run in those temperatures?
Offline Dimitros
  • 75
I would go only with full synt 75W-90 gear oil, even though I'd live in hot Florida or California! Don't understand the economy of $10-$15 and having issues in winter, worse mileage and worse wear and tear of transmission/diff components.
Just my 2 cents.
95 Samurai, 1.3, high comp.pistons, ported/grinded head, 1.6 valves, bored intake, Solex carb, K&N air, MSD Coil-Blaster+MSD 8.5 wires+Denso Iridium IW16 plugs, Calmini Tri-Y heder, Cherry-Bomb+Bosal custom exhaust, GRS II 4.89 T-case, 3.92:1 R&Ps, Calmini 3.5" susp., 30" BFG ATs, AVM 538 hubs...
