Technical Discussion - Beginner / Repair
temp gauge not working
jxben16
October 06, 2009, 08:21:10 AM »
i have a 95 sidekick jx 16v and i just picked it up about a week ago and did a fuel pump in her. gas gauge still doesnt work but i can live with that. however the temp gauge doesnt work. any ideas on how to fix it?
thanks.
Drone637
8121
116
Evil Cow
Re: temp gauge not working
October 06, 2009, 12:41:42 PM »
If both gauges are out it might be a grounding issue in your dash. One way to test the temp gauge is to check to see if the temp sensor is working properly first. Check the resistance on the sensor and make sure it changes as the vehicle warms up.
If it doesn't then your sensor is bad and will need to be replaced.
jxben16
October 06, 2009, 01:24:13 PM »
iv always been a ford guy so i dont know much about these sidekicks but im really diggin them so im tryin to find out as much as i can. whats odd is the temp gauge just started working
but yea the fuel gauge doesnt work but maybe its a float issue? i just replaced the fuel pump two days ago.
Drone637
8121
116
Evil Cow
Reply #3 on:
October 07, 2009, 01:55:03 PM »
Did it work before replacing the fuel pump?
ack
1659
34
Professional askhole
Reply #4 on:
October 07, 2009, 04:02:29 PM »
The temp gage is mounted just below the thermostat housing on the front of the intake manifold.
Often, the spade connector get corroded and may develop an intermittant connection.
Occasionally, the temp sensor goes bad but mostly the connector tab breaks off the end of it making it useless.
The temp sensor gets it's ground through the intake casting so any actual wiring problems will be between the sensor connection and the gage on the dash - not very likely.
I hope this helps!
Ack
Ack's FAQ
http://www.acksfaq.com
jxben16
Reply #5 on:
October 08, 2009, 12:56:04 PM »
haha its so f'n weird, the temp gauge works but the fuel gauge does not. im pretty sure all i did was wiggle the temp gauge wire around then in worked. oh well i guess i cant complain too much...
akfedor7
62
I Love ZUKIWORLD!
Reply #6 on:
October 10, 2009, 06:54:12 PM »
weird... again, my 95 tracker has this problem too! Gas gauge works, but temp only works when idling... start going down the road and it drops all the way. Stop at a redlight for a sec, and it comes up to normal.
1997 SIDEKICK SPORT, stock for now...
Jookycola
372
1995 Tracker LSi 4x4 16v 2-door
Reply #7 on:
October 13, 2009, 05:30:49 PM »
hahahahaha
OK this IS weird!
I also have a 1995 tracker and the same thing happens. When standing still the temp gauge works, accelerate and the thing drops all the way down. Come to a stop it creeps back up and works normal.
How do i find the grounding issue on this then? Where do i start looking first?
[/url]
fordem
4314
167
Reply #8 on:
October 14, 2009, 05:42:08 AM »
Find where the dash grounds to the body and clean it - what's happening now is it's grounding via the speedometer cable.
'98 SQ420 Grand Vitara
'05 JB420 Grand Vitara
