Auto tranny went out on Sidekick
  • 26 Replies
  • 7670 Views
« on: October 04, 2009, 05:12:54 PM »
I have a 95 JS tin top that the tranny (4 speed auto) quit. When it's cold it will move forward and reverse, but within a few minutes, it will not move at all. It starts whining like theres a stripped gear. Fluid is good and up to level. Previously, it would not up shift to second gear until the tranny warmed up. Also it would jump when backing up if throttled up. It has about 120,000 miles on it. Trying to decide if its worth rebuilding, or maybe dropping a complete 4.3 vortech/tranny/transfercase from a S-10 Blazer rollover I have. Haven't seriously looked at the complications of that swap yet. Hard to find anything on the web that tells exactly what transmission it has in it. I have heard that some trannys were ISUZU, some where GM.
Offline keith
  • 1176
Re: Auto tranny went out on Sidekick
« Reply #1 on: October 05, 2009, 06:04:34 AM »
The 4 speed is made my Aisin.  They supply a lot of transmissions to Japanese vehicles.  The previous 3 speed was made my GM.  It was a TH180 (aka Chevette transmission).
« Reply #2 on: October 05, 2009, 06:35:11 AM »
Are they expensive to get rebuilt? I had a feeling the three speeds were the Chevette trannys. I've looked at the pan, and it does not really match any of the drawings I have seen. Closest one I saw was a 4L30E.
Offline keith
  • 1176
« Reply #3 on: October 05, 2009, 06:54:08 AM »
I got a quote 3 years ago for $750 for a rebuilt 3 speed.  I have a feeling the 4 speed would be a lot more since it is computer controlled.
« Reply #4 on: October 05, 2009, 06:32:05 PM »
Thanks for the heads up on the manufacture, I think what I have is the 03-72LE /A44DE. I will have to pull it out this weekend and check it out. Pretty big transmission for a little four banger! Shouldn't be as heavy as the cast iron four speed manual I just put back in my F350 ton truck though! what a pain! had the added weight of a power takeoff for the dump bed too.
« Reply #5 on: October 07, 2009, 05:21:51 PM »
Dropped the pan tonight, apparently the previous owner changed the fluid but not the filter. It was pretty nasty. It was so clogged that when I dropped it, about a half pint of fluid came out from behind it. The pan was sludgey, but there were no metal particles or shavings on the magnets in the bottom. Going to pull the cooler lines and check to see if the cooler is clogged too.
« Reply #6 on: October 07, 2009, 06:12:33 PM »
Think you might get lucky and just be able to put in a new filter and fluid?
« Reply #7 on: October 08, 2009, 05:41:36 PM »
Hope so, looks to be a pain in the rear getting the tranny and transfer case out. The fluid was clean and not burn't, and with the abscence of metal particles in the pan, I'm hoping that with the clogged filter, there was not enough pressure to engage the gears. When its cold the oil is thick enough to work, but quickly fades when it warms up.
« Reply #8 on: October 10, 2009, 10:00:16 AM »
Clean out the valve body, it will work like new for a little bit of your time.
New fluid knocks the old crap loose and then it gets wedged into the workings
of the valve body, pull the tubes, drop the body, watch and write down all
that parts as they come out, keep an eye out for ball bearings that are hanging
on with the trans fluid waiting to jump out and bounce on the floor.
Honestly this isn't a hard fix, just watch your parts and clean it well with brake cleaner,
you also are going to need a gasket kit for the trans, as the thin paper one between
the plate and the halves of the housing is going to break apart
good luck
« Reply #9 on: October 15, 2009, 05:32:21 PM »
Changed the tranny fluid and filter tonight, decided not to attempt cleaning the valve body yet, I like to have diagrams in case I forget how something goes back together. Added almost a quart of Lucas transmisson fix also. Now the whine is gone, but still will not work in reverse and now stalls in drive, so as soon as I get a manual on it, I will go through it and see whats up with it.
« Reply #10 on: October 16, 2009, 12:21:42 PM »
Thats why I keep a cheap digital camera close by. If its a job I haven't done before I photograph everything as it comes apart.
« Reply #11 on: October 16, 2009, 04:41:10 PM »
Good idea, but my luck is something falls out and I didn't see where it came from originally ::)
« Reply #12 on: February 15, 2010, 04:54:03 AM »
Still haven't fixed the tranny yet, since I changed the filter and fluid, it now will go in drive, but not in reverse, as wildgoody said, it probally a clogged valve body. If it will ever warm up down here I will have to drop the pan again. It's a shame, because with all of the snow we have right now, I cannot get out and play in it!
« Reply #13 on: February 15, 2010, 06:25:39 AM »
IMO, the best way to change out the fluid is to pull the rubber return line that comes from the cooler and pump all the old fluid out that way.  You get a much better fluid replacement that way, instead of just dropping the pan and replacing what little fluid is in the pan.  To pump the fluid out....pull the line, put it into a big bucket (so it won't come out when the fluid starts pumping), start the vehicle and shift into drive, when the fluid stops pumping, shut off engine and add some new fluid to the tranny, repeat previous procedure until the fluid that is getting pumped out is clean fluid.  Once clean fluid is being pumped out, drop the pan, clean the pan, change the filter, put a new pan gasket on (unless it is a rubber pan gasket that is still in good shape, then you can reuse it), reassemble everything (don't forget to hook the line back up that you pulled to drain/pump the fluid out), and refill the tranny.  Warm up tranny and recheck fluid level.
I have used the above procedure for a tranny that was not shifting correctly and it fixed the problem.  I believe my problem was a gummy valve body and it eventually got flushed out and started operating correctly, once I got some new fluid in there.
Offline dustybadlands
  • 169
    • dustybadlands treeslammer
« Reply #14 on: February 15, 2010, 07:48:33 AM »
Like Rhinoman says....keep a digital camera around.     Then send us a write-up WITH PICS!
"If nuthin' changes, nuthin changes. Do what ya  always did, get what ya  always got !"
