Fed ECU in a CA Sidekick
  • 1512 Views
Offline RJkick
  • 631
« on: September 15, 2009, 12:19:05 PM »
Does anyone know if running a Federal ECU in a CA '92 4 dr sidekick will cause any issues
Lower mileage
stalling
etc.
I know it will cause a CEL code 53 which tells me it is the wrong ecu
Any Thoughts
Thanks
92 Sidekick 1.6L 16v Calmini\OME 4.5" lift 3" Body Lift OME962 springs in front w\.75" spacers OME955 in rear w\1.75" spacers Extreme Duty Strut Eliminator kit and rear ProComp MX6 Shocks 31X10.50 Nexen M\T   Thorley Header   2" exhaust  Calmini front truss bar and stabilizer and skids   Custom Bumpers and Rock Rails  Limit Straps
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
Re: Fed ECU in a CA Sidekick
« Reply #1 on: September 17, 2009, 12:04:03 PM »
« Reply #2 on: September 17, 2009, 12:46:44 PM »
I should think that you can run a Fed ECU in a California car, my understanding was that the CA car has an extra sensor for EGT so a CA ECU in a Fed car would throw a code.
There was some speculation that CA and FED was determined by the presence of an additional ground in the CA car. If not it will most likely be by configuration resistors inside the ECU.
