how to make doorless samurai ???
  • 10 Replies
  • 5526 Views
Offline derteracing
  • 52
« on: September 06, 2009, 03:30:21 PM »
So ive talked to people in the past that have taken the doors off there samurai. theres supposed to be a certain technique. well its time i want to and well i kinda forgot what they told me to do haha go figure right. Can any one tell me how to do this. Your supposed to make a certain cut on the hinges so they come off and on real easy. anyone know where that cut is? and does anyone know if i can relocate the stock mirrors and if i can where is a go place for them where i can still see? thanks for any help. oh and pictures and ideas and examples are much appreciated thanks
If oils leaking out, Dirts not getting in!
Offline RHodge
  • 523
Re: how to make doorless samurai ???
« Reply #1 on: September 06, 2009, 05:55:28 PM »
OK
# 1   disconnect the battery
# 2   get two screw drivers a #2 and #3 Phillips
# 3   remove the door stop strap
# 4   shut the door
# 5   remove the four screws the hold the door to the body
# 6   carefully open the door and carry it off
# 7   make or buy mirror mounts
# 8   reconnect the battery
# 9   take for a drive
Offline zukimoo
  • 330
« Reply #2 on: September 06, 2009, 06:08:37 PM »
I've done a few and after fighting with those phillips screws I've all together given up on taking them out in one piece.
Get your welder and buy some nuts that will cover the phillips door screw. I grind the paint off the phillip heads and weld on the nuts. Let them cool and put a wrench on them and yank them off. Take off the door straps first other wise you'll be trying to hold it all together.
Once you got the doors off then it's time to cut the hinge to make it removable. You've got to cut the top half of the female part of the hinge. This is the part that is going to be bolted to the body. You take out the top part of the C.
Once you cut the top of the hinge you can use a punch and take out the cut part. This will give you the finished hinge on the door. Now you rebolt the body part on the samurai and trim the pin down to be able to get the door on without having to unbolt anything. TRim a little at a time and keep trying to put the door on. I cut it about 1/2 way and it always seems to work....better to cut twice then to cut too short. I've done many and I've never lost a door.
I'll try to take some pics tomorow to show how it's done. For the mirrors I just welded a nut onto the hinge and made a bracket that could bolt onto the nut. I'll take some pics of this too.
06 Baja Buggy
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #3 on: September 06, 2009, 06:53:17 PM »
a search for door at my favorite website turned up these links:
SAMMY SCREW Solution (zuwharrie.com)
Cutting Hinges (Izook.com)
Removable Doors (izook.com)
I hope that this helps!
Ack
Offline zukimoo
  • 330
« Reply #4 on: September 06, 2009, 07:18:07 PM »
I'll try the air thing when I have to do the next one. I've got one to do in the yard but it's already got hex bolts.
06 Baja Buggy
Offline derteracing
  • 52
« Reply #5 on: September 06, 2009, 07:23:10 PM »
Thanks for the info guys i think i got the idea of the hinge cut. i havent broken any hinge bolts cause i havent ever taken it off. im going to try and cut it while its on the car. i just need to find a dremel tool. may just buy one sounds like a good investment. The only isue i have is that i have to find a spot for the mirrors were there out of the way and can still see. send me some mirror pics please.
Offline ack
  • 1659
    • Ack's FAQ
« Reply #6 on: September 07, 2009, 11:42:04 AM »
I'd like to see some pics, too!  ...or maybe a link to a thread.
Unfortunately, the one at Ack's FAQ no longer works properly
I built a bracket that bolts to the window hinge for the driver's side but the door slams into it causing it to bend.  I need a better solution...
Ack
Offline derteracing
  • 52
« Reply #7 on: September 07, 2009, 05:21:10 PM »
yeah i was thinking of making a bracket off that or just the window frame. ill let you know what i came up with. antone pictures?
« Reply #8 on: September 07, 2009, 11:58:51 PM »
After destroying my stock mirrors on random trees that jumped out at me I switched over to motorcycle mirrors.  Then just made a bracket that went on the doors and one on my roll cage.  Works great, keeps the mirrors in the stock location and all I need is a 14mm wrench to swap them out.
After the TTCW I am going to go back and re-paint the brackets black so they match the rock sliders and stand out a bit more against the red.
Offline zukimoo
  • 330
« Reply #9 on: September 08, 2009, 06:15:00 PM »
I've got a simple mirror solution. I did it with the LJ and it will work on the samurai too.
Weld a nut unto the top hinge part...the one that is on the fender. I used a coupling but that I trimmed down a little, a regular nut was too thin and a full coupling nut was too long.  I just made a simple L bracket and at one end there is a hole to bolt it to the welded hinge nut. At the other end I just bolted a 6" round mirror.
I can put it on and take it off with my bare hands. Just spin the bracket and it looses or tightens the bolt.
I'll try to take some pics but this to me was the simple solution. I tried to make it permanent on higher but I could never get a clear view of the mirror, had to bend over to look. It makes the mirror low but I find it works real good. Since you got the door off that leaves  you with a great open side view of anything right to your side. You just need to see behind you. I didn't put one on the passenger side because I didn't think it was worth the effort.
06 Baja Buggy
Offline derteracing
  • 52
« Reply #10 on: September 09, 2009, 04:54:08 PM »
well i bought myself a present yesterday. got me a dremel. i worked on the passenger door after school today. it was a bare but i got it done. i still need to clean it up a bit but i need more dremel tools. driver side is going to be easier and will probably look better tooo considering i know what im doing now. in thinking of just welding a tab on the hinge and seeing what pep boys has for mirrors. thanks for the ideas and help guys. ill put some progress pictures up lateer
