mini spool
  • 1211 Views
mini spool
« on: July 24, 2009, 06:29:41 AM »
I have a samurai and I am looking at getting a mini spool. I have heard that the mini spool breaks stock axles. Its not a dailey driver and it gets towed to the off road park. Most of my offroading is mud and very little rocks. Would i have to worry about snapping axles?
Re: mini spool
« Reply #1 on: July 24, 2009, 10:28:16 AM »
A fun thread comparing the options.  http://www.zukiworld.com/forum/index.php?topic=24758.0
I have run a mini spool since the beginning and have only gone through one set of rear axles in 5 years with 33x12.5" tires.  I haven't taken my current ones out to look at them recently though, we'll see how well they hold up with the new rear suspension.  If you end up toasting a couple sets you can get Heavy Duty rear axles that should be up to the task.
Re: mini spool
« Reply #2 on: July 24, 2009, 11:48:50 AM »
ANY locker will make axle breakage more likely. In a open diff, the power goes to the tire with the least traction. So - when one tire has very little traction, and another tire has great traction, the low traction tire spins (zero stress on axle with traction). With a locker - power will still go to the axle with great traction... so, if you're applying axle-breaking torque & weight to that axle... SNAP.
A selectable locker is the most gentle, but it costs $1,200. An auto locker will allow the free-tire to spin a little - then lock - creating shock load. Shock load = more likely to break. A spool is always locked, so loads tend to be more transitional (instead of shock loads). That's not to say auto locker = exploded parts.
So, ranked by "safe" for your axles:
* Open diffs
* Selectable locker
* Spool
* Auto Locker
There's way more pros and cons to consider before buying a locker - check out the link above. For what it's worth, I'd recommend a spool for your rear (cheap, reliable, and reasonably safe for the axles), and auto locker for the front (easier to steer). Unless you can afford selectable lockers.
