![](http://photos-a.ak.fbcdn.net/photos-ak-snc1/v2162/1/12/642127906/n642127906_2105744_9191.jpg)
This is my 97 2 door vitara front drive shaft yoke hitting the clutch housing when backing up or downshifting in 4wd when the pinion mount broke loose like this
I had to weld the nut back on because it had broke loose and worked its way through the center plate
![](http://photos-f.ak.fbcdn.net/photos-ak-snc1/v2162/1/12/642127906/n642127906_2105749_507.jpg)
Then just one month ago this happened again under severe conditions when i was backing up harshly to avoid rolling the vehicle over. This time the clutch housing broke and the oil pan was severely bent, but not punctured...
So be aware zuki fans, if you bash your car, this is a weak point.
![](http://photos-b.ak.fbcdn.net/hphotos-ak-snc1/hs163.snc1/6089_150808977906_642127906_3459513_7749990_n.jpg)
