drive line slip
  • 1300 Views
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
drive line slip
« on: June 28, 2009, 06:08:29 PM »
i have an 87 sami  i had a u-joint let go to today and it trashed the short piece of the rear drive shaft.
so i was wondering if i could take that piece off a front drive  shaft
r the drive line splines the same front to rear?
Offline Vagabond
  • 95
Re: drive line slip
« Reply #1 on: June 28, 2009, 07:25:46 PM »
Been there, done that.  You can take the "ears" off the end of a front (remove the u-joint), and use them in the rear (with a new u-joint).  Consider that your rear shaft may have slipped out, bent backwards, and destroyed the "ears" when it bent over and broke the u-joints with it.
[/url]
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
Re: drive line slip
« Reply #2 on: June 28, 2009, 08:58:59 PM »
the ears on the flange side are undamaged its the short female part  of the shaft that is all messed up
i was lucky i felt the u-joint brake on the free way i pulled off then seen the ear on the shaft was all bent from the joint brakin
i hate china made parts!!!!!!!!!!!
Re: drive line slip
« Reply #3 on: June 29, 2009, 02:10:06 PM »
Always go with either stock replacement or the Mitsubishi joints that Trail Tough has available.  We have learned that lesson a few times.  :)
