Another use for a Sammy T-case....
  • 3216 Views
Offline mcbrat
  • 19
« on: June 26, 2009, 07:36:08 AM »
Use it to help a 4 wheel Independent suspension Soob into a Solid axle rig...
1982 Subaru Brat
Subaru Engine & Subaru 5 speed transmission with hi/lo t-case
Samurai t-case hi/lo tcase
Trail Tough Rear Drive disconnect
Toyota driveshafts (lengthened)
Toyota Solid Axles.
linked with TJ Coils.
T-case cradle
Finished shots
Build Thread for you Fabrication types  :)
http://www.ci4wi.org/Portal/modules.php?name=Forums&file=viewtopic&t=341&start=0&sid=ff7b5950b8d0e0b7f450df409cd98610
Samurai t-case, surrounded by a Subaru Brat.  linked with Toyota axles and 35" tires.
Offline muskegtracker
  • 273
  • 10
  • Mr T
Re: Another use for a Sammy T-case....
« Reply #1 on: June 26, 2009, 08:18:28 AM »
NICE! 8)
91 Chevy Tracker
Offline mrhawk
  • 130
  • I Love ZUKS
« Reply #2 on: June 26, 2009, 08:57:08 AM »
Very cool build!  ;D
« Reply #3 on: June 26, 2009, 09:37:31 AM »
Ok, that's tricky.  :)
Offline locjaw
  • 2045
  • 22
« Reply #4 on: June 26, 2009, 01:01:40 PM »
That is sofa king cool. i always wanted a soob brat, that makes me want it more!!
Offline mcbrat
  • 19
« Reply #5 on: June 26, 2009, 01:29:11 PM »
the stock soob axle ratio was 3.90, so with the increase to the stock Toyota 4.10 gears, and the reduction in the high range of the sammy t-case, it almost completely takes care of the tire size change from 23" (stock) to 35"  (except for the weight difference of course)
and, I was able to use a stock sammy speedo cable, as it fit right into the soob cluster....  I just need to use my gps to determine the difference from the speedo, and make a new dial....
« Last Edit: June 26, 2009, 01:31:02 PM by mcbrat »
« Reply #6 on: June 26, 2009, 02:58:19 PM »
Holy crap that's awesome  :o
Offline Lindenmooch
  • 560
« Reply #7 on: June 26, 2009, 09:53:41 PM »
You said it jeremiah!
Holy crap indeed!
Offline 4Zstracker
  • 250
« Reply #8 on: June 28, 2009, 05:23:50 PM »
If you want a "Trar", This is so much cooler than an El Camino. Very nice, I like. ;)
if ya always do what ya always done, you always gonna get what ya always got...
