charcoal canister removal
  • 1788 Views
« on: June 08, 2009, 03:38:49 PM »
I have a 88.5 sammurai and i just installed a weber carb and electric fuel pump. I would like to remove the charcoal canister but i dont know what to do with the line that goes to the gas tank or the line that goes to the carb. Just wandering if anybody has any ideas.
Re: charcoal canister removal
« Reply #1 on: June 10, 2009, 01:52:18 PM »
Not real sure about a carbed Sammy, but I removed mine on My Tracker, just put a cap on the vacume solinoid line, and put a small filter on the end of the hose from the tank. I believe the line from your carb may be a vacume line? If that is the case, you can just put a plug cover on the port. Better ask another Sammy owner though to be sure.
« Reply #2 on: June 11, 2009, 10:11:27 AM »
I have weber carb with the vent line going to the canister so i think i could just put a filter on that line just like the the line from the gas tank and hopefully that will not cause any problems.
« Reply #3 on: June 11, 2009, 10:24:45 AM »
I don't think you want to leave a vacume line from the carb open. If your not actually using it, I would cap it.
« Reply #4 on: June 11, 2009, 12:47:29 PM »
I could re-route the line from the carb to one of the capped off vacuum ports on the intake.
« Reply #5 on: June 11, 2009, 07:26:32 PM »
cap off everything except the fuel tank vent. I just used a length of fuel line that goes from the vent tube then up to a loop then back down. This way water can't get in. You can also remove the o2 sensor and any other sensors not needed with the weber anymore.
