RRO body lift question
  • 1444 Views
Offline orcatdog
  • 24
« on: May 28, 2009, 04:58:06 PM »
I just installed a 2 in. RRO body lift last night.  I pulled up a tech build with pics and directions.  My question is that there are two mounts that they recommend "glueing" with black rv cement?  How long would these hold?  Is there any problems with just leave them out?  Also had a hell of a time with my shifter boots.
Offline Bryce132
  • 117
Re: RRO body lift question
« Reply #1 on: May 28, 2009, 07:08:46 PM »
Glueing?
Are those the front mounts you are talking about?
Shifter extension varies from model to model to year to year....
Have you checked your steering shaft? It MAY need to be extended as well. If you can weld its very simple, I used water pipe for mine... haha..
Bryce
Offline 4Zstracker
  • 250
« Reply #2 on: May 28, 2009, 09:37:18 PM »
So, I just bought that kit. Should be here in a few days ;D!
So does any body know what years etc have what issues with steering shaft and shifter extensions?
Mine is a, 1996 2 door 5 speed, its a tracker too if that makes any difference as opposed to a sidekick for that year.
if ya always do what ya always done, you always gonna get what ya always got...
Offline bzzr2
  • 1011
« Reply #3 on: May 29, 2009, 06:34:33 AM »
ya glue em in there like it says, i did with mine and have had no problem, they're surprisinsly still in there
09 taco reg cab short box 4x4
Offline orcatdog
  • 24
« Reply #4 on: May 29, 2009, 08:36:13 AM »
Ya, it said to "glue" them with black RTV glue.  They are the mounts about 3/4 of the way back, right in front of the rear tires.  They have no bolts, the mount just had a rubber knob on it to sit in the frame.  I ended up just leaving mine out.  Might put in later.  I figure 8 out of 10 aint bad :laugh:
I don't think I have problems with the steering shaft.  But I am having a hell of a time with the shifter boots both tranny and t-case.  I'm about ready to just take the console completely out.  I've all but ruined my boots screwing with them.
Any suggestions on the boots / console would be greatly appreciated.
Oh by the way, mine is a 95 sidekick 4 door.
Offline scoutman73
  • 14
  • 1997 Suzuki Sidekick Sport , some mods.
    • Flickr, pics of my Sidekick Sport
« Reply #5 on: May 29, 2009, 09:30:45 AM »
I guess I was lucky to have an auto trans. when I installed my 2" lift . For the transfer case shifter , I just cut the boot out and stuffed an old black sock around the base of the shifter to keep the road noise and dirt out , works ok .
  I would install the two spacer blocks if I was you . RRO would not add the spacers in there kit if they were not needed . They only give you the bare minimum of parts in there kits .
Suzuki Sidekick Sport 1997 1.8L auto 4dr.
ZOR winch bumper , Smittybuilt 8000lb winch
RRO rock sliders , 2" body lift, OME springs, struts, Jeff's spacers
Goodyear MTR's 245\75\16, 1.5" wheel spacers
Pics of my Suzuki Sidekick http://www.flickr.com/photos/20915236|removethispart|@N08/sets/72157614268325908/
Offline bzzr2
  • 1011
« Reply #6 on: May 29, 2009, 12:24:36 PM »
if you destroy your current boots just pick up some cheap aftermarket crap, that's what i had to do..
