30 9.5 15 tire question
  • 2633 Views
Offline Mudskipper
  • 21
  • Drive it like you stole it !!!
« on: May 27, 2009, 01:56:55 PM »
Will 30 9.5 15's fit on stock samurai steel wheels? If not, what size (width)? 7.5? Also. where would one find some this size? New? Used? Any help would be most welcome...........:)
Offline Uncivilized
  • 1469
    • Car Domain
Re: 30 9.5 15 tire question
« Reply #1 on: May 27, 2009, 03:33:05 PM »
Stock rims are too narrow, however I have seen it done. 7" wide rims from a Jeep CJ will fit the bill.
Offline Mudskipper
  • 21
« Reply #2 on: May 27, 2009, 04:04:46 PM »
That's what I was thinkin'.......thanks for the info......:)
Offline Merlin93
« Reply #3 on: May 27, 2009, 05:23:28 PM »
My tire, the BFG TA/KO, specifies 6.5-8.5" rim width for the 30x9.5R15 size. BFG specifies 6.0 -7.0" rim width for their very similar 235/75R15 size.  I"m on 7" wheels and will move up to one of these two sizes. But, a lot of guys do use narrow rims and seem to get away with it. The big problem, if I remember rightly, is that tires tend to come off narrow rims when aired down and on-the-road handling can get squirrely unless the tire pressure is high. The good news is that a 9.5" tire probably won't need a wheel with reduced backspacing (negative offset) to avoid rubbing.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #4 on: May 27, 2009, 07:35:22 PM »
...as well the contact pad arches more if too inflated.
Offline bzzr2
  • 1011
« Reply #5 on: May 28, 2009, 07:12:39 AM »
i run 10.5's on stock 6inch wide wheels with no issues.
09 taco reg cab short box 4x4
