To answer your question, the bellhousing is the same pattern, but it won't work that easily. The flywheel on the 2.0 is about 3" thick, it won't fit in the 1.6 bellhousing. And the 1.6 fit flywheel won't work on the 2.0. The flywheel has an 8 bolt setup on the 2.0, and the 1.6 and smaller use a 6 bolt pattern.
