largest tire on stock 01 tracker lt
  • 17 Replies
  • 2676 Views
Offline revolved05
  • 29
« on: May 09, 2009, 06:53:50 PM »
hey hey new on here, just picked up a 01 tracker lt, like the vehicle it self, hate the rim/tire sizing...ugg.
im not trying to go too crazy with this thing, just trying to improve light off roadabilty and def improve the looks...
thinking of possibly going for the little lift and a rim tire combo, not sure..
but i would really like to know what is the largest size tire a bone stock 01 tracker lt will run?
01 tracker lt,bone stock... for now...
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: largest tire on stock 01 tracker lt
« Reply #1 on: May 09, 2009, 07:59:29 PM »
Here are a couple of threads from the search engine on your question.  there are more under "tire size".
http://www.zukiworld.com/forum/index.php?topic=11542.0
http://www.zukiworld.com/forum/index.php?topic=7874.0
Offline nprecon
  • 2318
  • 52
« Reply #2 on: May 10, 2009, 06:14:37 AM »
Then if you just want an economical, dependable lift go with Jeff Hoepkers coil spacers, a new set of longer shocks in the rear and a strut body or strut shaft spacer.  Your truck will be sitting like the one in the enclosed picture.
Offline revolved05
  • 29
« Reply #3 on: May 10, 2009, 06:27:20 AM »
cool thanks,i was having a hard time finding a answer with out the spacers, but if im going to invest in the tires,whats a couple more bucks for spacers...
see the stance of yours nprecon,thats what im looking for.perfect.
Offline revolved05
  • 29
« Reply #4 on: May 10, 2009, 06:58:35 AM »
well, i cannot find a link to pick up a set of jeff's spacers...seen em before but cant find it now!
also what shocks go in the rear,and what strut body /or strut shaft spacer?
really appreciate all the help, i hate navigating search's !ahhh
2001 4 door Tracker. 2.5 V6 4x4
235/75/15 Firestone Destination A/T's
Jeff's 2" spacer lift
Offline revolved05
  • 29
« Reply #6 on: May 10, 2009, 12:38:48 PM »
saaaweeeeet 8)
Offline revolved05
  • 29
« Reply #7 on: May 10, 2009, 12:47:57 PM »
but what longer shocks need to be purchased?
Offline nprecon
  • 2318
  • 52
« Reply #8 on: May 11, 2009, 10:05:49 AM »
I just bought a set of rear shocks from a 90's model Crown Victoria.  Some people have gone with mustang shocks, some use Ford F-100 shocks.  Buy the shocks with 2" more travel and 2" longer when compressed than the stock units as well as having a lower loop the same as or VERY close to the factory Kick/Tracker shocks.  In most applications, you're better off taking a hacksaw and cutting the loop off the factory Kick/Tracxker shocks and then cutting the rubber bushing off the metal sleeve and reusing the metal sleeve in the new shocks in order to tighten up the bushings.  I re-used my stock lower shock bolts to mount mine.  I also bought a set of poly bushings instead of the factory rubber bushings.   Snugged them up with the bolt and they ride nice.  If you don't use the metal sleeve and/or the shock you select doesn't have a thick enough bolt in it, it won't be long before the bolt crushes down the bushing and you'll soon be getting some banging in the rear.  Make sure the bushing/bolt set-up is snug in the shock loop.
« Last Edit: May 11, 2009, 10:21:54 AM by nprecon »
Offline nprecon
  • 2318
  • 52
« Reply #9 on: May 11, 2009, 10:11:58 AM »
A very useful tip before you start installing the coil spacer lift (if this is the first time you have screwed around with suspensions) is to spray all the bolt threads in the suspension system (sway bar, strut bolts, tie rods ends, shock threads) with PB blaster (etc) a day before you start your project.  Makes a world of difference in reducing some of the aggravation factor when you begin your project.
« Last Edit: May 11, 2009, 10:20:03 AM by nprecon »
Offline revolved05
  • 29
« Reply #10 on: May 11, 2009, 06:57:48 PM »
awesome!
90's model crown vic and jeff's coil spacer kit and rock and roll... niceeee
this is my first truck im toying with... just got rid of my beastly 240sx... time to stay out of trouble
Offline bzzr2
  • 1011
« Reply #11 on: May 12, 2009, 01:22:02 PM »
go mustang shocks, about an inch longer than the crown vics when extended and the mounts are perfect - direct swap.
09 taco reg cab short box 4x4
Offline revolved05
  • 29
« Reply #12 on: May 12, 2009, 03:33:27 PM »
even better im guess mid 90's mustang?
Offline TopHeavy96
  • 488
« Reply #13 on: May 12, 2009, 04:28:20 PM »
I'm using 95 mustang KYB shocks,  I slighty modified the upper bushings to fit the Tracker frame. Lower sleeve fit with the factory bolts.
Offline revolved05
  • 29
« Reply #14 on: May 13, 2009, 04:39:28 AM »
this is looking good so far, pretty cheap for just enough lift, most expensive part looks like tires itself...
