Tracker SAS w/ sammy axle - track width issues
  • 64 Replies
  • 19380 Views
Offline explosivo
  • 3157
Re: Tracker SAS w/ sammy axle - track width issues
« Reply #30 on: August 03, 2004, 06:20:03 PM »
I think I've talked to you about widened sammy front axles before... unfortunately just the axle would be more than the cap on my SAS project :o. Otherwise I would because I assume they are damn good axles (the same Heather and Nate are using in their kick, right?).
omghi2.us[/url]
Offline idaholwb
  • 772
« Reply #31 on: August 03, 2004, 06:29:42 PM »
 The ones that are coming with this and the rest of my front ends are different than the ones in previous versions, mine and Heather's included. The shafts and birfs are made by a different outfit, and come with a Lifetime Guarantee.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline explosivo
  • 3157
« Reply #32 on: August 03, 2004, 06:33:54 PM »
Same cost? Higher? I'm cheap and lazy.
omghi2.us[/url]
Offline idaholwb
  • 772
« Reply #33 on: August 03, 2004, 07:15:43 PM »
 About the same cost.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline Underpressure
  • 48
  • Twist and shout!
« Reply #34 on: August 04, 2004, 02:53:39 AM »
The Tracker/Kick 3rd member fits like a glove into the front Sammi housing. No extra parts needed.
Offline explosivo
  • 3157
« Reply #35 on: August 04, 2004, 10:46:00 AM »
Does the kick rear steel carrier fit into the front Sammy axle? If so, I think I might be all set.
Otherwise I'll have to have one of those special machined sammy carriers made up for my axle :-/
« Last Edit: August 04, 2004, 10:46:38 AM by explosivo »
omghi2.us[/url]
Offline Mike71
  • 1449
« Reply #36 on: August 04, 2004, 01:42:13 PM »
didnt u just pay for that calmini 3" sus lift lol..and now u want to go sas..sigh
Offline explosivo
  • 3157
« Reply #37 on: August 04, 2004, 04:05:11 PM »
Yeah, I bought that lift about 6 months ago... I just HATE CV shafts... I've had to take each one out two or three times a piece to change the boots or put them back together after they pull apart. >:(
I'm just not a happy camper.
Plus, these are future plans... the far, far future of next summer or the summer after...
omghi2.us[/url]
Offline idaholwb
  • 772
« Reply #38 on: August 04, 2004, 04:20:30 PM »
No, the kick rear steel won't fit in the sammy, either end without a hybrid housing of one way shape or form.
97 Sport
265/70-16s
2" lift
2.0 swap
  • 48
  • Twist and shout!
« Reply #39 on: August 04, 2004, 05:30:33 PM »
Why not leave the rear diff as is, and and swap the front kick' 3rd member(that's the one that fits) into the front sammi housing for your SAS front diff. (mabey I'm confused)
 If you need a hybrid housing, however...I make them.<--Jay
« Last Edit: August 04, 2004, 05:32:02 PM by underpressure »
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
« Reply #40 on: August 04, 2004, 06:30:09 PM »
  How much for a hybrid front sammy/kick axle? Are you using resplined rear axles up front or chromoly. Plus which birf's are you using, sammy or subaru?
  • 48
  • Twist and shout!
« Reply #41 on: August 05, 2004, 06:20:29 AM »
I am building rear hybrid housings, and assembled units. If I knew there was a call for front hybrid housings, I'd be happy to look into the cost of building them.
 What qualities would you look for in a front housing? Track width? Stronger front axles? Birfs, or U-joints? Would it be set up for leafs or coils??
 Hit me with some specs. <---Jay
Offline explosivo
  • 3157
« Reply #42 on: August 05, 2004, 01:31:51 PM »
Front 3rd: aluminum
Rear 3rd: steel
I do plan on leaving the rear alone for the SAS, I just wanted to know if it was possible to fit the rear 3rd member from my parts kick into the front Samurai axle, which it seems it isn't. :-/
omghi2.us[/url]
Offline idaholwb
  • 772
« Reply #43 on: August 05, 2004, 06:10:11 PM »
 If you want the widened sammy front for a kick, or a hybrid front, I make them.
97 Sport
265/70-16s
2" lift
2.0 swap
  • 48
  • Twist and shout!
« Reply #44 on: August 13, 2004, 06:11:12 PM »
like I said.....hit me with some specs.
And the cost of yours is>idaholwb?
« Last Edit: August 13, 2004, 06:12:10 PM by underpressure »
