Thought I would update this...
I've tinted the windows 5% on the three rears, front brow, and 35% on the front sides (don't want to draw TOO much attention from local law enforcement)
I feel like I can pick my nose in privacy now
but seriously, whenever I actually DO have the windows rolled up, it seems like it's much nicer inside. Not so much glare compared to the clear windows before. A/C is nice too
Added some small doo-dads including a flashlight bracket above the driver's side door opening that bolted to the nuts welded in the roof where a grab handle was supposed to go. I'm 6'1" tall and have learned to duck my head a little extra with those flashlights in the way. With them mounted, it's that much less stuff rolling around inside the car. Dash-mat, AVS window visors, hood visor, I have some ricer-taillights coming soon (they may look cheesy but I got the black ones since I'm chromophobic and the black matches all my bumpers and fender flares better). Replaced some rear seat hardware from Hawk Suzuki so now my rear seats fold forward and STAY forward.
I think I'm going to make some one-off pedals out of a thick piece of aluminum diamond plate I have sitting around, and bolt them to the original pedals. Seems like the OE pedals are a bit too small for my size 12 boots. When it's raining my feet slip off
Since I burnt my clutch in early June, the car has been sitting. Once again, I've spent my entire summer NOT driving it! Ironic.
What's happening (one SLOW step at a time):
new clutch KIT (not just the disc, but full kit, bearings and all). I took the advice on here and up-sized to the 16v clutch, it's slightly larger, not much, but still it offers more grabbing surface area.
resurfaced flywheel
rear main bearing seal
re-seal oil pan
distributor o-rings (I will add RTV to the housing o-ring to really seal the hell outta it)
new valve cover gasket (since I pulled the valve cover)
replaced various missing bolts on the engine. Long story, whoever installed the exhaust on this did a crappy job on a lot of things...including leaving two bolts out of the driver's side engine mount, and two more bolts missing on the header flange, when they installed the Thorley header. These are things that a monkey would have noticed when installing a header. They also welded part of the catalytic converter's heat shield directly to something that bolted to the transmission, so it had no "give" and the weld broke and rattled. I was upset, but relieved when I found it was a crappy piece of metal rattling and not my CAT that I thought I was going to have to replace for the past month of driving. The heat shield itself was ugly, too, it has 10 screws holding it on to the cat, and a bunch of boogerwelds...why you would need screws AND welds baffles me...
Also, instead of using a lock-washer or fiber lock-nut on something on the exhaust, this guy double-nutted it and welded the nuts to the bolt. So I had to cut this particular piece off because it was a welded mess that wouldn't give.
The guy then had the nerve to spraypaint his shop's name on the muffler. If I did work like that on a customer's car, I wouldn't want to advertise MY name. What a crock.
replaced the hard plastic front fender linings with a soft rubber liner. It's got nylon webbing reinforcement similar to a truck mudflap. VERY strong. I was going to initially use vinyl construction base but it felt too weak and soft and I know it I was going fast enough and a rock was in my tire, if it flew out of the tread and hit that, it would probably shoot right through it, it's so soft. This stuff is pretty damn durable. It's called "PVC-90" if anyone is interested. Hoping it will be quieter if a rock flies out of the tire. And the old plastic ones were cracked and had broken at the bottom near the rear of the front fender, letting lots of debris in. These new ones I made seal everything up tight now. At the same time, incorporating mudflaps and flexy fender flares for both front and rear fenders (I will post pics of this later as it's still a WIP, almost got the fronts done, rears will be easier since I am not adding a fender liner). Rear fender flares will extend past the rear quarter panel and drop down an additional 8" or so, supported by the mudflap and a small support I'll fab later.
new horn (triple-bell horn, who knows what it came off of, but when I had it on my truck before, it sure got people outta my way!). It's going to be mounted under the driver's seat area, between the rocker bar and frame. Will post pics of this too
fresh rebuilt transfer case with 4.24:1 gearset, courtesy of Trail Tough, and a twin stick shifter from Rock4x. This is the biggest thing I am looking forward to. Twin stick will give me 2LO and a true neutral for flat tows. 4:1 will be simply amazing for crawling along the trails this hunting season.
bumpin' stereo. The Xplod deck and 5-1/4" rear speakers that came with the car are good, I upgraded the front 4" to Xplod 4" last year, it all sounds great, I can hear it on the freeway with the windows down at 70mph, but it completely lacks bass...so I stuck with the Xplod name brand and got a slimline amp (XM-1S), and a slimline 10" subwoofer in a box already set up (XS-LB10S) and will set it behind my rear seats, keeping it covered up with a blanket or something so it's not visible from the outside. Probably hide the amp inside the rear quarters and mount it on some rubber blocks to isolate vibrations.
It will sound better inside, the fender stuff and mudflaps will keep it cleaner, the engine stuff will eliminate leaks (I hope), the clutch will improve drivability, and the gearing will take it anywhere I want it to.
If I have time, I will round up the parts for my front sway bar disconnects. I've already got them planned out, but just have to gather parts. Might take a whole day of calling around and driving to pick up parts. But, it'll be worth it to have them.
After hunting season it will get some black paint below the windows to cover up the flaking white, and an urban-camo theme overlay on the bottom half (like two-tone) to cover up where some previous owner stripped the old plastic strips off. Those two things alone will make it look 10x better by covering the worst areas of paint on the car.
Then I will see about a rear locker. I would love to go with the KAM kit but I don't know how much longer I shall have to wait to see it for sale...
