1990 Tracker tintop build
  • 117 Replies
  • 39007 Views
Offline meach4x4
  • 59
Re: 1990 Tracker tintop build
« Reply #105 on: November 14, 2010, 09:46:59 PM »
Eh, gear oil is cheap.  15 bucks for another gallon is reasonable when asking for peace of mind...
When you installed the gears, didn't you have to clearance the inside of the case?  If so, it is a good idea to drain and replace the oil after driving a hundred miles or so to get any shavings out that may have not been flushed out during the install.  I know I cleaned out every tiny bit of shavings I had, and still had some in the oil when I drained it after the install.
Offline meach4x4
  • 59
« Reply #106 on: November 14, 2010, 09:55:49 PM »
And with the new tires (30x9.50R15) and stock gears, 5.125:1, thiis how I was running at 55 and 65
Have you adjusted your speedo for the larger tires?  I am running 30x9.50x15 BFG AT KO's on my 96 4 door and my speedo is reading about 10% low.  At 65, my GPS is a tick above 70 mph.
Great job on the build.  I'm working my way through a similar build, but at a slower pace.
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #107 on: November 15, 2010, 12:19:52 PM »
No adjustments.  Just the mental adjustment (remembering it is +/- 10% under)  ;)
When I was going 70 on the highway I suddenly realized that actually means 77mph...don't wish to risk going any faster.
Don't these speedos register a little over when stock, anyways?  So it's probably not as far off as I think?
Offline fuzzy1
  • 350
« Reply #108 on: November 20, 2010, 03:04:30 PM »
My '96 reads nearly exact (via radar) with 235/75r15's on it, so yes they tend to read fast with stock tires.
Non Illegitimi Conterat
Offline djlantis57
  • 871
« Reply #109 on: November 22, 2010, 11:35:31 AM »
I know before I put on the 30's and it had the 235s on it when I first bought it, it was pretty much dead-on whenever I drove by any of those radar speed-checkers like they post in front of schools around here.  It's probably off by just a little but I'm still conscious of my speed.  I figure staying just below the speed limit on my speedo puts me right about at the speed limit...never had trouble from the :police: but keeping my fingers crossed.  At least fender flares and mudflaps keeps me legal in that regard, one less reason to be pulled over...hey I still have to post pics of that!
If you don't see the pics soon someone remind me.
Offline djlantis57
  • 871
« Reply #110 on: November 24, 2010, 06:07:44 PM »
http://www.zukiworld.com/forum/general-suzuki-forum/fender-flares-with-mudflaps-on-tracker/
 ;D
Offline Medford
  • 184
« Reply #111 on: November 28, 2010, 11:24:59 PM »
dj, your ride is always full of ideas, keep going on it bro.
Offline vw505
  • 133
« Reply #112 on: March 10, 2011, 08:35:54 PM »
do anything new? Where did you get your CB antana mount from?
Offline djlantis57
  • 871
« Reply #113 on: March 10, 2011, 09:11:50 PM »
Here in Fresno called Red Monkey.  If you don't know where they are, it's kinda tricky to describe but they're west of Golden State north of Shaw ave.
The mount is Firestik brand, I just dug up my receipt in my "Tracker file" and their invoice calls it a "hatch back mount #FSSS204."
I just now typed in "SS204" on Google and discovered that's the part number.
Works real well, it perfectly misses the door when in the closed position.  I couldn't have asked for a better setup.
I have two pictures here:
http://www.zukiworld.com/forum/build-diaries-how-to-diy/1990-tracker-tintop-build/msg211214/#msg211214
I notched the taillight opening and added a grommet to protect the coax, ran it inside the rear fender behind the interior paneling, shoved an electrical fishtape through the rocker panel and have it routed out of a factory wire grommet under the dash on the left side.  Behind the four bolts holding the bracket on are fiber-lock nuts, and also a metal plate about 1"x1" with four holes drilled to tie everything together on the backside and act like a really big washer for all four bolts.  Pretty damn stout.  Driven it everywhere and haven't had it cause problems (only a rattle, but that's the rattle from the quick-release I have on it).
Just a tip:  I had the L-shaped part of the bracket (where the antenna actually mounts) flipped to make it an extra inch taller...but that was too much leverage, no matter how much I tightened the allen set screws the damn thing would rotate.  The way it is now (see pics) is 1" lower than I wanted, but it does not budge at all
Offline vw505
  • 133
« Reply #114 on: March 01, 2012, 06:06:21 PM »
How did you mount the front plate on the TT bumper.
Offline djlantis57
  • 871
« Reply #115 on: March 01, 2012, 07:25:35 PM »
Dang thanks for reviving my thread. Lost track of time lately...just remembered I still have to post a thread on how I did my rear air bags.
What plate are you referring to?
Offline vw505
  • 133
« Reply #116 on: March 01, 2012, 08:46:54 PM »
The licence plate
Offline djlantis57
  • 871
« Reply #117 on: March 09, 2012, 03:02:10 PM »
The licence plate
Never had a front plate when I bought it almost three years ago.  Haven't bothered the DMV since to get a new set either.
I haven't had any hassle about it either *knock on wood*
