lockright locker
  • 21 Replies
  • 3867 Views
Offline jeff5000
  • 37
lockright locker
« on: May 07, 2009, 09:03:47 PM »
just installed locker few months ago did every thing acording 2 instructions but it dosent seam 2 be slipping in turns at all no clicking sound just tire skuffing churping so tor it back apart other day and the springs were all messed up what am i doing rong aney sugestions i got the locker with cupplers do i use aney kinda thrust washer
Offline rascott
  • 669
  • 15
Re: lockright locker
« Reply #1 on: May 08, 2009, 10:14:37 AM »
did it start off working right?
sounds like perhaps the springs failed to line up on final assembly?
i reused my side gears.
i worried |removethispart|@ lining things up and saw those springs as a challenge.
Offline djlantis57
  • 871
  • Take your chrome home
« Reply #2 on: May 08, 2009, 11:45:56 AM »
Yes i plan on adding lock right lockers to my 1990 2dr hardtop Tracker.  Trail tough makes a trick FRONT locker, in addition to the rear.  But I don't understand the side gears option that most websites list.  Do all axles have these side gears, and it just gives you an option to replace worn out ones, or what?  How would I tell if they are worn out?
Offline jeff5000
  • 37
« Reply #3 on: May 08, 2009, 12:20:46 PM »
no it dident start off working right
« Reply #4 on: May 08, 2009, 01:17:41 PM »
I just installed a lockright yesterday and I will get the axles back in tonight. What kind of locker did you use. If it was a lockright did you put the double springs in the bigger holes and the pins in the smaller holes to in each plate of the locker?  TShaw
T Shaw
Offline rascott
  • 669
  • 15
« Reply #5 on: May 08, 2009, 08:20:46 PM »
that's what i was thinking- and i've only delt w/mine, so ........
as i was assembling, i was very concerned w/scrunching those springs by not lining it up just right.
i think i figured a way of keeping it compressed so it couldn't get out of line 'till it was together.
if you're kit came w/spares, mabe "just" try it again. betcha looking forward to that!
i found the project satisfying but difficult. must be easier the next time.
can't imagine anything else would be damaged?
Offline jeff5000
  • 37
« Reply #6 on: May 08, 2009, 08:46:55 PM »
every thing looked fine except 4 the springs  i had it apart twice its not 2 bad 2 take apart im just frustrated as 2 y it wont work right
« Reply #7 on: May 09, 2009, 05:13:07 AM »
My locker install ended up with new brakes, a broken bolt in the top of the rear third and the rear A frame bolts seized in the bushings. Thank you Michigan and salt on the roads.  TShaw
T Shaw
Offline Lindenmooch
  • 560
« Reply #8 on: May 09, 2009, 06:04:03 AM »
isn't that what happens when the rear is locked, and both tires are moving at the same speed??
why would you expect it to slip? or click?
what kind of locker is it?  is it a permanent one, like a spool?  or selectable via air or electric?
Offline norcalwreckchaser
  • 128
« Reply #9 on: May 09, 2009, 10:40:21 AM »
Sounds like a Lock Right E-Z locker to me, they make a noticable clicking sound when they disengage, this is normal. If you don't hear anything you have a problem.
Norcal
Sold 7/10 :(
« Reply #10 on: May 09, 2009, 11:19:04 AM »
Has anone ever used a additive with their locker?  My local auto parts store sell one made by kendall that is recomended to help ease the clicking as it locks and unlocks.  TShaw
T Shaw
Offline jeff5000
  • 37
« Reply #11 on: May 09, 2009, 12:07:26 PM »
it dose not click it stays solid all the time thats how i kno it is not working riight and it is power trax lock right
« Reply #12 on: May 10, 2009, 11:35:06 AM »
i had the same problem on my europian sidekick 4-door v6 try a different brand of locker
Offline JayInBarrie
  • 107
« Reply #13 on: May 10, 2009, 06:20:53 PM »
Last year I bought a Lockright locker for my 99 tracker.  Which is fine except that I swapped a 98 Sidekick third in for the lower gears (and SOFT removal), so I installed the wrong locker.
So I installed the wrong locker into my differental case.  Was to tight of a fit, so no clicking, occasional screaching.  By the time I could take it out, one of the spacers were busted.
Lockrights sending me a new spacer (love the customer service).
I'm sure you have the right locker, but good to check.
You've checked and tips on acksfaq?
http://www.acksfaq.com/pdfs/Backlash.pdf
99 2dr Tracker, 33" tires stuffed in, home made roof rack.
Offline djlantis57
  • 871
« Reply #14 on: May 10, 2009, 08:39:44 PM »
