kevins offical replacing the clutch on sunday I need help g&a
  • 17 Replies
  • 2591 Views
Re: kevins offical replacing the clutch on sunday I need help g&a
« Reply #15 on: April 29, 2009, 02:26:03 PM »
Dont know abou tthat but the diameter of the center hole seems much larger on the new one, will that mess you up  ??? Or is it just teh angle of the pic.
xkmail
« Reply #16 on: April 29, 2009, 06:20:58 PM »
I used the clutch alignment tool the centers are both 20 spline and same size.
The funny springs are not springs they are called rubber diafram bumpers or something.
It is an OEM style clutch that makes the clutch engage and disengage smoother
strictly a DD type setup, used on toyotas alot from factory.
Offline 95 Tracker
  • 33
« Reply #17 on: May 02, 2009, 06:15:53 AM »
SO I am looking at the exedy clutches oem style
I can get a<br>
04137     1990 - 1990     TRACKER BASE     California Emission and Heavy Duty; L4; 1.6L; Non-Turbo; Gas(ALL)
Disc Outer Diameter     215mm(8-7/16in)
Spline Teeth / Major Diameter    20T / 7/8in
<br
or a <br>
04108     1990 - 1990     TRACKER BASE     7-7/8" Disc; L4; 1.6L; Non-Turbo; Gas(ALL)
Disc Outer Diameter     200mm(7-7/8in)
Spline Teeth / Major Diameter    20T / 7/8in<br>
Both are 20spline, one is larger.
Guess if I am getting my flywheel redone might as well go CA heavy duty.
Mainly daily driver, very little desert riding.
i'm looking for a new clutch too but the California emissions vehicles big price difference cali more $
and i drive a cali
so that worked out a cali clutch on a federal vehicle
« Last Edit: May 02, 2009, 06:21:06 AM by 95 Tracker »
