kevins offical replacing the clutch on sunday I need help g&a
  • 17 Replies
  • 2592 Views
xkmail
Ok.
90 tracker 8V 5 spd 4X4.
First, haynes says i need to remove the shifter.
I got the plastic and boots pulled back.
Do I remove the bolt that goes from side to side on the shifter?
It says something about pull up and twist counter-clockwise but I think that is the samurai
11:36 am
Offline olija
  • 770
    • Check out my cardomain
Re: kevins offical replacing the clutch on sunday I need help g&a
« Reply #1 on: April 26, 2009, 12:56:22 PM »
Nope, you don't need to remove those bolts. Feel the collar that the shifter is sitting in. Push down on it and you will feel it is spring loaded. If you push down on it and turn it counter clockwise about 1/4 or 1/2 a turn, it will release and you can pull the shifter out with ease. It's probably easiest to do it in Neutral.
xkmail
« Reply #2 on: April 26, 2009, 01:22:12 PM »
won't go.
I see the ring and small spring in there, I can push it down maybe 1/4" (with fingers or screwdriver) but shifter will not turn.
Do I need to pull the shifter up or push it in to turn it?
xkmail
« Reply #3 on: April 26, 2009, 01:24:30 PM »
On other notes:
drained transmission and transfer case
removed both driveshafts 4- 14mm bolts each(marked with nail paint).
removed starter 2 11mm bolts
Removed breather tube and wire harness from behind distributor area.(10mm)
Unbolted trans from cross member./14mm
A plain 2X4 or 4X4 behind distributor????
xkmail
« Reply #4 on: April 26, 2009, 01:32:46 PM »
OOOOOOOOOOOOOHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!
Push the ring down and twist the RING 1/4 to 1/2 turn.
i was pushing on the ring and twisting the shifter..
OK, done
 ;D
xkmail
« Reply #5 on: April 26, 2009, 04:37:37 PM »
Tranny out.
6-12mm bolts holding on pressure plate.
tranny adapter is 4X17mm and 2X10mm.
Anyways, clutch and pplate don't look bad.
But its out.
once I pull the bearing and stuff I guess I'll put it back together.
I am thinking it could be a tranny issue too...
xkmail
« Reply #6 on: April 26, 2009, 06:19:27 PM »
SO I am looking at the exedy clutches oem style
I can get a<br>
04137     1990 - 1990     TRACKER BASE     California Emission and Heavy Duty; L4; 1.6L; Non-Turbo; Gas(ALL)
Disc Outer Diameter     215mm(8-7/16in)
Spline Teeth / Major Diameter    20T / 7/8in
<br
or a <br>
04108     1990 - 1990     TRACKER BASE     7-7/8" Disc; L4; 1.6L; Non-Turbo; Gas(ALL)
Disc Outer Diameter     200mm(7-7/8in)
Spline Teeth / Major Diameter    20T / 7/8in<br>
Both are 20spline, one is larger.
Guess if I am getting my flywheel redone might as well go CA heavy duty.
Mainly daily driver, very little desert riding.
« Reply #7 on: April 26, 2009, 09:47:51 PM »
I like the petro works dual friction clutch setup myself.
Offline sir lance
  • 342
  • I love my XL-7
« Reply #8 on: April 26, 2009, 11:20:46 PM »
your pressure plate may  look ok, but it may not be , if your going to reuse it, when bolting it down to the flywheel, make sure all the fingers pull in and are uniform.
personally i would replace the clutch, you have come this far already.....
-Lance
xkmail
« Reply #9 on: April 27, 2009, 08:28:38 AM »
Oh I'm doing a whole new clutch kit, rear main seal,e tc.
But $300 for a petroworks, nope, not worth it on a DD to me
« Reply #10 on: April 27, 2009, 09:20:27 AM »
I'm putting one in now for a friend that is in his mid seventies that said the same thing, he drives it to work and also on fire roads on weekends, I put in a reconditioned flywheel, a new pressure plate and disk, it lasted about one week be for it looked like yours, so he saved about 25.00 over a good one but he did get a week out of it, now I'm doing the right way Like I wanted to, you never know if your just going off the road for a look at something and you hit what looks like a small water hole in the road and bam your flooring it trying to get out and there goes your clutch!
xkmail
« Reply #11 on: April 27, 2009, 09:33:49 AM »
So how does the oem clutch from the factory go 60K ?
I don't see petroworks at the dealer
Offline locjaw
  • 2045
  • 22
« Reply #12 on: April 27, 2009, 11:12:18 AM »
1990 has a 5 digit odometer so it only goes to 99,999. thus i would have to say your tracker has 160,000 miles on it
« Reply #13 on: April 27, 2009, 03:24:16 PM »
oem=ideal condition, petroworks= give it hell and it will ask for more, have a nice time at the mall with out it is what I'm saying, maybe us old guys just wheel harder with out trying, LOL.
xkmail
« Reply #14 on: April 29, 2009, 01:37:27 PM »
OK, no petroworks comments please.
Got in my gripforce clutch, went to 8 7/16 size from 7" size.
the new clutch plate (on the left) has these weird pieces where the springs were, any comments?
But the new pressure plate holes forthe pegs line up nice on the flywheel.
Local shop flywheel resurfacing $35
