steering questions
  • 1570 Views
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
steering questions
« on: August 23, 2004, 03:31:45 AM »
Ok. I already have a Spring over axle lift. Everything in the suspension and steering is stock suzuki. I have some extended brake lines, and I am about to put some better leaf springs on it. The springs will lift it about 2-3 inches. My question is, do I need a longer pitman arm, or a longer link that runs from my pitman arm to my steering? I am asking because I want to make sure I have all of the right parts before I begin...
Thanks
Offline okezuki
  • 51
Re: steering questions
« Reply #1 on: August 23, 2004, 06:15:22 AM »
Go with some sort of knuckle-over steering.I run a Breeze set-up & have had no problems. My buddie`s got the Spidertrax & it is nice also. I am spoa w/ cj`s & missing links. These systems will preety much take care of bumpsteer. ;D
87,33`s,6-1 t-case,d.c.drive shafts,locked,m/l with cj`s,dt8000`s,& the will to BEAT THE SNOT OUT OF IT!
Offline 1bigtracker
  • 3409
« Reply #2 on: August 23, 2004, 06:37:41 AM »
 i like the sky-manufacturing crossover kit, and at 170 bucks, you can't beat it.
http://www.sky-manufacturing.com/
stu
« Last Edit: August 23, 2004, 06:37:57 AM by 1bigtracker »
Offline DoctorD
  • 68
  • No such thing as too many toys!
« Reply #3 on: August 23, 2004, 08:36:39 AM »
I'm runnig an Acme hi-steer.  It's a very nice set up, and it only took me 45 minutes to unpack it, charge the compressor and bolt it on.  Check them out at:
http://www.acmeadapters.com/
So, did ya find any springs yet?  I'm thinking either YJ's or CJ's would hold up that small block...they work in the heavier Jeep.  If ya went with the stock Jepp springs, you's get a little lift out of em.
D
In search of new toy
Offline suzi_n_sammy
  • 184
  • Rock the Sam
« Reply #4 on: August 23, 2004, 02:12:30 PM »
stu
^^^Sweet kit right there. my buddy has one on his sammy, very nice.
You can take the Sammy off the trail, but you cant take the trail out of the Sammy.
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
« Reply #5 on: August 23, 2004, 03:32:32 PM »
  Look into the Calmini kit once they were available.
Offline 1bigtracker
  • 3409
« Reply #6 on: August 23, 2004, 04:21:30 PM »
D
i might be stupid but how do you get into their site???
stu
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
« Reply #7 on: August 23, 2004, 04:25:37 PM »
click the spinning logo thingy.  ;)
