This bad boy's donating an engine / trans / t-case to my SJ410, the toy axles, 35" Toyos, and (future) half doors to my '96 4-door. The body & frame's being converted into a trailer.
I was originally a little hesitant to chop it up, but the more I did, the more I uncovered the kind of Mickey Mouse engineering that caused it to catastrophically fail several times on my Rubicon run last year.
Two goals:
* Larger capacity for camping.
* I'll be making it "sleepable" for 2 during inclement weather -
heavy wind in high desert
sucked in a tent at KOH '09.
Gutting & Stripping - a sawsall with sheet metal blade (Harbor Freight) worked like hot knife through butter on the sheet metal. HF 4 1/2 grinder with cutting disk worked better on frame.
There was an old cement mixer laying around - the width matched the frame perfectly. Destiny?
Unfortunately, I didn't measure as much as I should have before doing all that shaving - it's a bit long:
I don't have pics of it yet, but I welded 2 1.5" DOM square tubes across the frame, shortened the tongue, and welded the tongue to the tube. I think it might be hard to put much junk in there without the tongue weight being too biased though :'( I don't know how I'm going to get around that - cut some length off the front, or move the axle forward?
