Rock rails
  • 10 Replies
  • 2301 Views
Offline Grandmaster
  • 43
Rock rails
« on: August 15, 2004, 07:57:13 AM »
What do you guys make yours out of?
I have 2.5 inch steel tube im going to sue as the rail and 1.5 steel tube to mount to the frame. how much is too much weight for these?
Offline MUTANT_ZUK
  • 152
  • Its only one of a kind if you make it!
Re: Rock rails
« Reply #1 on: August 15, 2004, 01:19:13 PM »
 I use 3" channel notched on one end for the tube and the other end square cut to weld to frame,or bolt to frame at body support brackets.If you are going to use these for rocker panel protection I would use heavy guage tubing or pipe and weld my support brackets to the frame because sooner than later you will high center a rock or something and these rails will be supporting a lot of vehicle weight (It just dont look cool driving home with your rails and rocker panels all crumpled,or your rails making sparks dragging along the road) Good luck! one good thing on a Sammie it dont take much material.  Later  M.Z.
Now thats stress relief 4X4!                  MUTANT ZUK
Offline Mike71
  • 1449
Re: Rock rails
« Reply #2 on: August 15, 2004, 02:38:12 PM »
also make sure that u dont accidently make a "rock hook" outa these things lol
i have seen a few that are to low or to square..they seem to catch more rocks then they should ever be near lol
Re: Rock rails
« Reply #3 on: August 15, 2004, 03:04:04 PM »
How about a full belly pan ??
I think it would do more than sliders
Offline Grandmaster
  • 43
Re: Rock rails
« Reply #4 on: August 15, 2004, 04:45:39 PM »
I was thinking about that. Just a sheet of metal the entire length. But then I thought about cooling, what would it effect? Since mine is my DD i think it may warm up too much without some sort of venting.
Offline MUTANT_ZUK
  • 152
Re: Rock rails
« Reply #5 on: August 15, 2004, 10:37:09 PM »
  I dont think you could close the under side up enough cause a over heating problem, that would take some serious metal fabbing.Belly pans are good ,but you need to make it easily removable for service and put some drain holes in it.I plan on fabbing one for the T-case,every thing else is pretty well tucked up high.  Later  M.Z.
Re: Rock rails
« Reply #6 on: August 15, 2004, 10:47:34 PM »
I used heavy 2x4 tubing for the slider with 2x2 running back to the frame. They are heavy but there is no chance of denting them ;D
Re: Rock rails
« Reply #7 on: August 16, 2004, 12:10:19 AM »
The weight ans strength of it will depend on the wall thickness of the metal as well as the size. I've seen some very hefty looking sliders fold up cos they were only 1mm (40 thou) wall thickness
Offline xamtex
  • 72
Re: Rock rails
« Reply #8 on: August 16, 2004, 08:14:29 AM »
god must love crazy people,he made so many of them!!!
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: Rock rails
« Reply #9 on: August 18, 2004, 03:57:12 PM »
LOCKED OUT...PRIVATE DISCUSSION IT SAYS  ;D
Offline Grandmaster
  • 43
Re: Rock rails
« Reply #10 on: August 23, 2004, 04:48:34 PM »
Well, I should start building these soon I guess.
Also looking into a sheet of metel for an entire undercarrage belly pan.
