shopping list for samurai power steering upgrade.
  • 1517 Views
Offline homer74
  • 193
« on: April 22, 2009, 01:51:50 PM »
Alright fellow zukers Wifey gave me permission for this upgrade, Need help with my shopping list any help is greatly appreciated. and thanks again for all of your help :).
Offline Luke
  • 43
Re: shopping list for samurai power steering upgrade.
« Reply #1 on: April 22, 2009, 08:16:34 PM »
 :o"Wifey gave me permission"  :o  Come on man, don't be like that.
« Reply #2 on: April 22, 2009, 09:48:49 PM »
Easiest is a tracker as a donor vehicle then just pick up the adapter kit from Low Range or Trail Tough.  Next is to use a Toyota as a base.  :)
Offline Amilla
  • 1076
« Reply #3 on: April 22, 2009, 11:14:44 PM »
Toy power steering is where its at!
Amilla
Offline homer74
  • 193
« Reply #4 on: April 23, 2009, 12:04:00 PM »
Thanks for the Info guys, Don't get me wrong love my Wife and money is tight and me being a ManChild I need supervision with money. :D
« Reply #5 on: April 23, 2009, 03:14:52 PM »
The sidekick stuff is good for DD/ small tire wheeling. Say up to a 35". If you are planning a hard core rock rig consider something more powerful. I have no opinion on the Toyota stuff as I have not used it.
« Reply #6 on: April 23, 2009, 09:34:31 PM »
I think Sky had a bolt in kit where as t.t. you have to drill two large holes and weld pipe in the frame, only one hole out of three bolts up, you can make the stock high pressure hose work and I had to remove the ac pump for more area, belt contact with 33's or the belt would slip and a big cooler is needed for large tires for going slow in rocks or snow. you will need to weld or buy a shaft coupler.
